Lt1 to LS2 swap?
Old 02-08-2011, 10:56 PM
klutch-'s Avatar
Default Lt1 to LS2 swap?
going pick up a 97 t/a with a LT1 in it with a blown head gasket.
i have a 6.0 lined up for the car but i wasnt sure what issues i may run into on the engine swap. any tips, tricks, advice??
thx in advance.
Old 02-09-2011, 02:44 AM
the_merv's Avatar
Is it a 6.0l Truck Engine or LS2?
Old 02-09-2011, 04:42 AM
klutch-'s Avatar
Its a 6.0 out of a 08 trailblazer SS.
Old 02-09-2011, 08:25 AM
Unertl42's Avatar
the reluctor wheel is a 58x instead of a 24x, so you can either pay someone to put a 24x reluctor wheel on the crank, or get Lingenfelter's conversion box.
Unlike the LS1, the LS2's knock sensors are mounted on the side of the block.
I'm sure I'm forgetting things
Old 02-09-2011, 10:27 AM
the_merv's Avatar
Cam Sensor is on the front..Valley Cover is a little bit different..
Old 02-09-2011, 09:45 PM
klutch-'s Avatar
ive been looking around and the only thing i have found was a corvette lt1 to ls1 swap. i was hoping to find a write-up or at least someone that has done the swap just to get an idea if it would be worth doing that or just fixing my lt and rolling with it.
Old 02-10-2011, 04:19 PM
Mooneyed's Avatar
Its basically the same as an LS1 swap.. Just minor details like previous members have stated..
Don't you have a writeup on your swap merv?
Old 02-10-2011, 09:20 PM
the_merv's Avatar
Here is the one for my LT1 car..
https://ls1tech.com/forums/conversio...to-95-z28.html
I don't have the one up for my Monte Carlo SS.. It's coming soon..
Old 02-11-2011, 02:18 AM
01ssreda4's Avatar
Psssh, you been saying that forever.
OP, there are only a few things different as me and a buddy are doing basically the same swap.
1. Crank reluctor wheel is the 48 tooth instead of the 24. You must run the newer sensor.
2. Crank is 4x reluctor instead of 2x and its on the front timing gear (not the back under the intake). You must run the newer front cover with new sensor and new timing gear to make that system function. You must extend the harness as well.
3. You need the LPE conversion box to dummy down the signal so the older computers can read the signals of the new sensors.
4. Knock sensors are the same but located on either side of the block not in the valley cover. You must extend the factory harness to reach.
5. The valley cover is different. You must run a Gen IV valley cover.
6. You can run Gen III or IV heads but the intake much match them, i.e. cathedral with cathedral or square port with square port.
Old 02-11-2011, 07:18 AM
Jeff Smith's Avatar
do 6.0 come with pcm? Don't have to change the reflector wheel.
Old 02-11-2011, 09:35 AM
the_merv's Avatar
Yes..it's been snowing here so progress is at a standstill with what I have to finish up.
58x Reluctor..
I dont think that stuff will work with a LS1 PCM..he may need to go to the LS2 Factory stuff..
Old 02-11-2011, 12:15 PM
Rockstar
Johnny-LT1-runner's Avatar
It'll work with a LPE conversion box.
Old 02-12-2011, 09:30 PM
ticketmaster86's Avatar
He will be fine with the 58X reluctor wheel b/c he's gettin the PCM and the factory wiring harness from me as well. He will be getting a complete LS2 with all accessories from oil pan to intake, belts to flywheel. Including all sensors. Now what we r tryin to figure out is how hard is it to drop the LS2 in place? Steering shaft r rack and pinion be in the way? What about crossmember? If the crossmember is in the way, could we pass with the C6 rear sump pan? How about the motor mounts?
Old 02-13-2011, 07:31 AM
01ssreda4's Avatar
Steering shaft and k member have to be changed over to the LS style. You may need the LS cross-member for the trans. You cant run a C6 pan in an f body. You have to run an f body pan. Motor mounts need to match the k member, LS type.
Old 02-13-2011, 09:11 AM
the_merv's Avatar
Will be Auto or Manual?
Old 02-13-2011, 10:03 PM
Thanks 01ssreda4.
Will be an auto for now. I'm sure he'll plan to throw a stick in there but who knows.
Old 02-13-2011, 10:58 PM
Mooneyed's Avatar
Originally Posted by ticketmaster86
Thanks 01ssreda4.
Throw a stall in it and be done!!
Old 02-14-2011, 12:51 AM
klutch-'s Avatar
well this whole build has switched to a LS1. sent a message to merv
Old 02-14-2011, 01:19 AM
the_merv's Avatar
Aw ****..
Old 02-14-2011, 01:38 AM
klutch-'s Avatar
Aw ****..
lol not aw ****!! this will be better for me i think... atleast more power for the money im gonna have to spend... more bang for the buck!
Quick Reply: Lt1 to LS2 swap?
