Kwik a/c brkt??
Old 05-11-2011, 09:33 AM
Old Geezer's Avatar
Question Kwik a/c brkt??
The app is on an LQ4, using the truck brkts and a Vette w/p w/spacers.
I am having problems with the belt running over the ft edge of the a/c compressor, and ruining the belt.
I've checked and rechecked the belt/pulley alignment while running and while static. I find no noticeable alignment problems.
The problem seems to occur when I go WFO... Usually after the 2-3rd run. [Shifting at 6K]
NE1 have suggestions????
Old 05-11-2011, 12:29 PM
TomM's Avatar
Yes, shim the bracket between the head and bracket with a washer or two. In other words, move the whole bracket out the thickness of 1 or 2 washers. Had the same problem on a buddy's car....solved it.
T,
Old 05-11-2011, 03:04 PM
Old Geezer's Avatar
Thumbs up Thanks, and..
T,
I sent Kwik an email. They called me back.
Here's what info I received.
1. Loosen all bolts, including the compressor bolts.
2. Pull up on the comp pulley, and tighten the 2 bolts going into the head.
3. Then tighten all others.
There has been a change in the tensioner pulley. [Yours is the "early" design if it's a smooth, metal pulley, with no "sides" on it.]
The new design is a smooth pulley w/ sides, and is plastic. Gates pt # 38012. An 18mm washer has to be put on the back side of the pulley so it doesn't hit the tensioner arm. This pulley w/ "guides" on it, will help align the belt onto the compressor.
The new pulley is about $20 from NAPA...
We'll soon know.. It's going back on the road this weekend
HTH!
Quick Reply: Kwik a/c brkt??
