Spark Plugs and Steam Vent hose
Old 10-20-2011, 12:37 PM
97s10ls's Avatar
Default Spark Plugs and Steam Vent hose
Just a couple quick questions
just got my 97 s10 running and
1) was curious to know what spark plugs should i use
2) does the steam vent need to be on the pressurized side or can i run it to the coolant overflow?
1997 s10
2002 6.0l
t56
TSP V2 cam
everything else is pretty much stock
Edit I answered my own question with the steam vent now i am just curious as what plugs to run.
Old 10-20-2011, 01:47 PM
Tongboy's Avatar
NGK TR55 is pretty much the standard plug to run
Old 10-20-2011, 01:50 PM
FatfreeGTO's Avatar
NGK TR55 is what I run in my 6.0
Old 10-20-2011, 04:04 PM
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
Stem pipe must run to the upper radiator hose. It can also run to the water pump. Check my build thread for exactly which side of the water pump, I forget.
Andrew
Old 10-20-2011, 06:19 PM
SSjon's Avatar
Steam Vent hose should be run to either the upper hose with a fancy fitting, or to a coolant degas tank. It can also be plugged after you get all the air vented out of the system.
Old 10-20-2011, 07:11 PM
bczee's Avatar
I run mine to the Radiator. The aftermarket Alum radiator that I have had a threaded port that was just below the Radiator cap (not the overflow) and in the tank.
other options have been the upper radiator hose (using a Tee), Water Pump (as already stated) and also the Heater Hose (using a Tee), along with the Radiator.
Old 10-20-2011, 10:37 PM
Mike52's Avatar
Is it the NGK TR55 V-Power, the NGK TR55 G-Power Platinum or the TR55 Iridium spark plug, NGK lists the TR55 3 different ways.
Old 10-21-2011, 03:16 PM
Altitude 65's Avatar
I use the Iridium.
Quick Reply: Spark Plugs and Steam Vent hose
