What exhaust manifold for a 65 chevelle
Old 11-22-2011, 07:25 AM
Chief25's Avatar
Default What exhaust manifold for a 65 chevelle
What exhaust manifold will work on the driver's side of a 65 chevelle.
Old 11-22-2011, 07:44 AM
bczee's Avatar
4th Gen F-Body should work. I think many are now trying the 5th Gen F-Body. Take a look at the late CTS-V ones also.
Most truck will not as they are too wide.
Vette one usually have problems due to the exit is centered and would run into the X-Member.
Old 11-22-2011, 04:59 PM
Fahrenschnell's Avatar
4th gen f-body will work but you will have to plug the 02 sensor hole and relocate it into your exhaust pipe downstream......
the o2 positioning hits...
Old 11-22-2011, 07:43 PM
Chief25's Avatar
Will a pair of 2010-11 Chevy Camaro SS LS3/L99 V8 Stock Exhaust Manifolds work on the 65 chevelle, I was looking on Ebay they have a pair off a 2010-11 Chevy Camaro SS LS3.
Old 12-03-2011, 06:47 PM
Chief25's Avatar
Old 12-03-2011, 08:17 PM
bczee's Avatar
from the pictures I have seen of them... it looks like it should work.. as they are rear exit like the 4th gens...
On the 99 F-body drive side.. yeah. it gets close.. I just welded it shut and drilled and welded a new bunt about 90* inborad and they work ok after that. (but I later went with Headers anyway).
Old 12-04-2011, 02:51 PM
rallystyle's Avatar
i think a trailblazer would work also.
Old 12-05-2011, 12:48 PM
Derailed's Avatar
I have the 2010 Camaro manifolds bolted up to my motor right now which is going in a 67 Lemans. I have not tried to drop it in yet but it looks like I will have to grind a little off of the outside of the manifold flanges to clear the frame. I am a little doubtfull because of the way the manifolds point straight down and not back at an angle but we will see. im also curious if the 98-02 long tube f body headers will work on a 64-67 A body.
Old 03-23-2012, 12:33 AM
Chief25's Avatar
Default 2010 Camaro manifolds
How did the 2010 Camaro manifolds bolted up, did they clear the frame ?
I am looking at the 2010 Camaro manifolds to. let me know if they clear the frame THANKS
Old 03-23-2012, 07:02 AM
LS1 pwrd NOVA's Avatar
Fbody manifolds work, may have to grind the flange on passenger a bit. Also i heard 08 + truck manis work. Heres some reading for u on my tests for headers
https://ls1tech.com/forums/conversio...ment-test.html
Quick Reply: What exhaust manifold for a 65 chevelle
