VSS and Low Oil Level Switch Delete Question
I am working on wiring my first engine in my brother tube buggy and am using information that has been provided on LT1swap.com. This info is very helpful and straight foward, but I have a few questions. It never mentioned me being able to remove the VSS sensors (my harness is from a '99 4wd 4L80E truck) so I have two sensors and they route back to C2 connections 20, 21, 22, and 23. Since this is an offroad buggy and will not have a speedometer, I assume I can delete them. Is this correct? By the way I am using a turbo 400.
Also LT1swap.com recommended removing C1 pin 70 (Low Oil Level Switch). This sounds like a good idea to me since the ride will be off camber a lot on the trails, but I was somewhat skeptical about removing it. This wasn't a typo was it? Thanks for any help.
Chase
Chase
Sounds good on the oil level switch.
Thanks for the help.
-Brendan.
So regardless using a non electronic trans requires a vss? I removed that wire!
[QUOTE=Silver2000WS-6;15780653]Ok, I guess I should keep both VSS sensors? Since I am running a turbo 400 trans will I just leave the plugs open? If I can just leave the plugs open, how would this be different than just pinning them out?
So I’m running a 700r4 and still will need the vss I’m understanding. I removed the wire this evening can put it back but what’s involved?
You're replying to a 7-year old thread.
