Need some wiring advice
I am using the underhood harness from an LS1 Camaro in my Chevelle and I am in the process of getting it hooked up. It looks like the Camaro used one 15 amp fuse for all 8 injectors and both coil packs. Is that too much for the circuit? The biggest issue I am struggling with is how to combine all 10 of those wires into one that goes into the fuse panel. I was thinking I could use a large 10 gauge crimp connector and put all of the pink wires in one end and then have a single one going to the fuse panel out of the other end. Will this work?
What's wrong with crimp connectors? I figured I would have to solder that bundle of wires but are the crimp connectors ok for splicing single wires? I cut the the plug off of the coil pack harness to make it a part of the main harness and crimped them together. Will that hold up since I wrapped it in electrical tape?
LS1Tech Sponsor
You can buy environmentally sealed crimp connectors similar to those used by GM in their factory harnesses. Be wary of solder joints in wiring harnesses. The solder joint is inherently brittle and can fail over time due to vibration. Not saying you cant do it, but you might want to strain relief the joint. Just my 2 cents.
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
I had to address a similar problem. I used one set of connections to merge the 8 wires down to 4 wires, then a second set of connections to take the 4 wires down to 2 wires, and then the 2 wires into the fuse block. Although I made more connections than absolutely necessary, I liked the way the wires fit when twisted together - I think I got a pretty good mechanical connection. I also increased the wire gauge as I consolidated wires.
Make sure you solder them together and if available, use an adhesive-lined heat shrink tubing. This will keep out air and moisture, and add strength and durability to the soldered area. You don't want to be digging through this harness looking for bad connections after everything is in your vehicle!
If you don't know how to solder, look at some youtube videos and then practice. It's important to get a hot enough iron - I like the Weller SP40L. Give it some time to heat up, heat the wire with the iron, and then push the solder into the wire. It's really not hard - practice on some scrap wire before you try it on your project. Make sure the wire is freshly stripped and clean.
I was surprised to see all of the injectors and coils powered off of one 15 amp fuse and a rather small 18 gauge wire. It looks like certain Camaros had fuses in the INJ-1 and INJ-2 spots, unlike my harness. Would it be worth it to add the wiring and have a fuse for either side?
