66 chevelle welded in engine frame mounts questions
Are these the correct engine frame mounts for a 66? The car had a BB before but i am about to do an lsx swap. These are welded in but are they in the correct location for any engine? If they are then i can start making my engine mounts around them or should i grind the welds off and bolt them in? I have no problem doing this either. I just hope i can reuse them if possible if not ill buy different ones or newer ones. I didnt actually see any for sale so dies anyone know where to get some or should i just buy whats out there but they do look different. Point me in the right direction but not the high dollar direction.....
Who did that welding ???.. with that job, I would grind the welds off and remove them. Start from scratch.
Measure how wide they are. I have been told or read that the BBC are the same ones as the SBC, but not having any BBC to compare. I would not know for sure. On the other hand, to me it makes no difference if the are SBC or BBC, If you can get the correct engine mount connected to the adapter plates then they well work.
I would bolt everything together (engine, plates, mount and stands). Drop the engine in and move / adjust to where you want the engine to be, watching out for areas of contact, the pan to crossmemeber, power steering box to accs, firewall, steering ends, etc.
Once you are happy with the location. Mark the location of the frame stands. Remove the engine, then either weld or bolt the frame stand to the Crossmember. Done deal...!
For the two types of engine mounts Tall/Narrow or Short/Wide.. go to page #16 of this catalog to get the measurements, that well help you get the correct mount to the frame stands that you have.
http://www.energysuspension.com/asse...on-catalog.pdf
Keep us posted and good luck.
BC
BC
I bought the car like this but I didn't pay attention to the mounts..... BC I was thinking exactly what ur telling me. Bolt the mounts to the engine, mount the rest together and drop it in. Set it on the xmember & make sure everything has room to fit then bolt the frame mounts in. This sounds easier to do than anything. Ill check out that link when I get to a computer.
Old School Heavy
That is not welding. A dog **** on there and they painted over it.
Seriously though. That is not correct and no adapters that I know if will work with that. The Edelbrock adapters use small block Chevy frame pads. The tall and narrow version if I remember correctly.
I can add that I had a 66-SS396 car and that the big block frame mounts are completely different than the small block versions.Check with Ground Up Restorations as to which stands were correct for your application. Big block cars also had the engine offset towards the passenger side slightly. I agree with BC that you should grind off both mounts and the leftover slag or weld and start fresh with new small block stands.
65 skylark is "speedtigger" is that who you were asking? or me 67Skylark? speedtigger has his done and running he has a good list of items used for his build under his post.
I have just started, so nothing complete or set in stone. Modified F-Body pan, Doug’s headers and adapter plates, 1 in setback and redrilled frame to setback an additional 3/4 inch, right head is about 3/4 inch from firewall. Drivers side frame mount will be the one in the picture, rh is custom made so I can keep the truck ac comp. I'm running an LY6 with VVT so all accessories are pushed forward.
Ron
Ron
I used solid mounts in my Chevelle too. I bought standard location adapter plates for my LS (share the bottom SBC mount hole with the bottom forward LS mount bolt hole). I hope the engine just sits right in the hole and bolts up with no issues.
