LSX notchback cost
Old 02-13-2012, 09:02 PM
kevins2000LS1's Avatar
Default LSX notchback cost
Well I was going to do a LSX notch few months ago. but changed my mind and was going to just find a higher mile c5 and put my new cam only LS6 in it. But just got my house and it need little details, so im not going to be able to pick up a $10-13k vette at this point. So with that said I already have the AJE kmember with LS1 mount and arms, and rear upper and lowers. I already have a set of weld draglites. And can get a 8.8 cheap. I can get a nice coupe body for $500 buck, So im going to list whai I have priced up and u guys guide me in more stuff I may need or dont need
1- cowl hood $300
2- th350 manual valve body and good stall? $ 1200
3- ls swap headers used or someones abandon project $500??
4- carb and intake and MSD box $800??
5- fuel system sumped stock tank and pump reg $500
6- trans cross member new price?
7- gauges, florida cluster with oil pressure temp tach and shift light ???
Old 02-13-2012, 09:30 PM
Zmg00camaross's Avatar
IDK but subscribed.
Old 02-13-2012, 11:14 PM
Spoolin_Notch's Avatar
what are you ultimate goals with the car? I'm also building one.
Old 02-14-2012, 06:08 AM
Goal is a low 10 sec coupe but can be driven on street @ 55 mph for no more than 30 minutes but can be driven and strong track runner. Not going to be gutted like a tin can just lightened up.
Old 02-14-2012, 08:35 AM
Dickie-311's Avatar
take it from me , your looking at a 10k bill
Old 02-14-2012, 10:57 AM
bjamick's Avatar
I think I'll be around $4500 total in my whole build.
Car 300
Headers/flange $300
harness/pcm $150
Engine $300
Driveshaft $400
engine rebuild parts/machine work $500
cam kit $600
Electrical parts $100
Radiator/fans $100
Transmission $350
Stall $325
rear end $350
Fuel setup $250
K-member $400
so $4425 total in what I can remember. Most numbers are actually rounded higher on some things.
Old 02-14-2012, 04:24 PM
10k I sure hope not! Well if u add the engine I already have current suspension parts and what I'll need it could get up there. Hope to build on a budget!
Old 02-14-2012, 05:38 PM
6.0L mustang philly's Avatar
checkout my build, i know im saving alot by doing my own fab work but as of now ive only got around $1200 in my project.
car is a 93 fox hatch i drove for over a year, 4cyl 5 speed 88k miles $350 ran perfect
engine i traded an lt1 with harness and ecu for a "knocking" LQ9 $450 is what i payed for the lt1
i got the harness and ecu from a buddy out of a 03 1500 LQ4 truck $250
manifolds are flipped and wrapped stockers
built some motor mounts
building my own harness
so far i havent bought any of the "swap" parts. even the stock 4cyl k member is in tact. i have a buddy with a deisel that gave me his old 3.5" exhaust. I lightly modified the 4cyl lower mounts to meet my scratch built uppers. i do still need to source a tranz and turbo. but im not breaking my budget to build this car. i dont plan on going over $2000 including a full paint job even the bay and to tune the ecu. everyone swears by the "aje" brand but after seeing one in person i know for a fact i can make stuff myself with the same build quality. i refuse to buy these hyped up swap components. headers would be nice but $900 for kooks long tubes? no thanks... besides whats the point of a swap project if your paying someone to build parts to make it bolt in? i build my stuff... just my .02 -phill
Old 02-14-2012, 05:43 PM
oh and also pick up a 93 fox body bro. they have a return line so you dont need a corvette fpr. and even the truck manifold will fit under the stock hood.
Old 02-14-2012, 07:28 PM
1bad03snake's Avatar
Im at a little over $2K in my swap car included. I still need a quarter stick, misc AN fittings, xpipe and mufflers, driveshaft.
Old 02-14-2012, 07:36 PM
LS1PUNK's Avatar
Im well over 20k in mine but Im not cutting corners and everything I bought is BRAND NEW.
Florida 5.0 gauges costed me a lil over $1k.
It could be done cheap, just not the route I wanted to go.
Good luck.
Old 02-14-2012, 08:57 PM
boostnut's Avatar
Here's where I'm at currently:
95 GT roller- $2250
2000 LS1/4L60 pullout- $1800
AJE k-member, mounts, & trans crossmember - $557
Circle D torque converter - $395
Truck coils (D585) - $125
stock maf - $50
oil pan gasket - $40
2010 camaro exhaust manifolds - $60
243 heads - $400
MLS head gaskets & tty bolts - $60
LS6 intake, injectors, rail, tb, & cam - $475
LS2 timing set, gaskets, balancer bolt.... $140
Next up is:
trans rebuild - $800 for the monster kit (free labor)
Wiring harness - $500 - PSI conversions is getting my business
Driveshaft - $300 ????
Might as well throw in another $300 for fluids and odds & ends.
I'm a little north of $8,000 but still not complete. Yeah, I paid more for my roller than most but its what I wanted. Already had all the suspension goodies, weld wheels, rust free.......
I do have about $500 worth of stuff to sell (wiring harness, coils, intake, ..........) but until I part with them they're not coming off my budget.
When its all said & done I'd bet my project exceeds 10K. When it hits the road it'll need tires, an alignment, new carpet, .... **** adds up.
Old 02-14-2012, 09:01 PM
Well with my current list of parts
Ls6
Aje kmember
Aje arms
All fbody accessories
Fbody fan and radiator
Double adjustale uppers and solid lower
Picked up a 4.10 8.8 tonight 200 bucks
I hope to finish including body hood wheels and fuel system and trans for 5k
Old 02-15-2012, 07:41 PM
penningta's Avatar
I would go with the new afco k member. I have heard some of some aje k members breaking. Im running the afco and it is a nice piece
Old 02-16-2012, 12:36 AM
c-ham's Avatar
here is where im at: i started with a 95 cobra with a 393 that i have parted out so, so far i have spent everyone elses money, the original price of car was 5800 i drove it for a year broke a lifter pulled motor and now im starting fresh.
ly6 find them for 1300-1600 all day long have money aside but havent purchased yet or i will hurry and start half assing things.
just ordered team z k member, A-Arms, coilover kit, motor mounts, hardware kit, and steering rack hardware kit, all for $850 shipped through kurgan motorsports.
got a flaming river manual rack kit with shaft tie rods etc used for 300 shipped plus my old PS pump and lines to the guy.
th 350 with shift kit $150 ( its not gonna last forever like that but will get me moving)
revmax 4k stall will be around $300
dynatech lt's, 600 hoping to get them cheaper through KURGAN Motorsports.
still need trans x member
still need carb, buddy has a bnib holley hp 750 for $150
still need inatke and msd box
electric water pump
hope to get my FMS aluminum driveshaft modified (havent looked into this)
still need a shifter
i will not worry about speedo etc, i have aftermarket tach oil pressure and water temp guages
other misc parts like alternator flex plate, stuts will be needed the only accesory i will be driving is an alternator, im going carb mostly because it will be primarily a race car and i want it to look super clean under the hood. plan to narrow my cobra r's in front have 26-11.5/17 rears 4.10s, girdle, sfc's, eibach drag launch rears comp 3 way rear shocks non adjustable control arms with solid bushing.
Old 02-16-2012, 12:43 AM
c-ham's Avatar
also need cam and timing set, im looking around 6-7 k in parts, but have sold/will sell close to 5k in parts worth of ford stuff, so that brings me in at around 1k in my roller which is a custom painted 90k mile never seen snow 95 cobra so by the time is said and done ill have a total of 7-8 k in a 10 second car NOT TOO SHABBY!!!
im buying used what i can and buying new what i have to.
Old 02-16-2012, 09:59 AM
ocp04's Avatar
HERES MY LIST
SUNSET ORANGE NOTCH 1800
TH350 TCI CONVERTOR AND AJE CROSSMEMBER 700
DRAGLITES WITH BRAND NEW MICKEY STREET RADIALS 300
SSP HARNESS AND PCM 425
DONOR CAR 3100 --- built rear end w/ gear, spool, axles etc. fuel tank and lines with a/n fitting for feed and return w/ walbro intank pump, aeromotive fpr, tubular rear suspension upper and lowers, aje k-member and arms, front coilovers, flaming river rack, f-body radiator and fans, complete black interior, dynatech headers, flexplate for th350, hurst 1/4 shifter, headlights, tail lights etc
5.3 truck motor 500
Old 02-16-2012, 11:27 AM
Yeah Im just trying to decided if I want carb and th350 or efi and t56
Quick Reply: LSX notchback cost
