Building or buying a custom fuseblock - What are my options?
I am planning my harness routing and fuse/relay panel and would like to use the Current Perfomance Wiring fuse/relay center,click here for details. I would also like to integrate both headlight relays into the fuse/relay panel, but there are no provisions to do so with their fuse/relay center. This Bussman setup would handle it, but I am having a hard time finding a supplier and it is overkill for my setup - http://www.connectorconcepts.com/pro..._files/VEC.pdf
I know I could mount the headlight relays by themselves, but I wanted to see what other options were available. It would also be a cleaner install if everything under the hood was in one centralized location (fuseblock/relay panel).
The local junkyards are pretty bare around here, so I am looking at buying the pieces and building it, or purchasing an off the shelf piece. I know this may not be the cheapest way to go, but I am not going to cut corners at this point in the game. I also want a sealed unit so the build your own like the one at lt1swap.com is not an option.
Also where is a good place to buy reasonably priced 18 gauge TXL wire without a 200ft plus minimum?
Relays- there will be no main power relay
~ Ignition power (fused)
~ A/C compressor (fused)
~ Fan 1 (fused)
~ Fan 2 (fused)
~ Headlight low beam
~ Headlight high beam
~ would like at least one spare relay socket
Fuses
6 ignition powered (2 spares preferable more)
6 battery powered (3 spares)
FYI - Fuel pump relay will be mount in trunk and the trigger will be run to the relay. Power will be tapped into on trunk mounted starter solenoid.
~ Fan 1 (fused)
~ Fan 2 (fused)
Fuses
I made my own and it was pretty easy. Especially after looking at the prices others are selling them for and they didn't totally meet my needs. Look at LT1swap.com there is a tutorial on how to wire a fuse and relay box.
I have the current performance fuse and relay block, very nice. Also, just bought 18ga txl wiring from eficonnection. $20 dollar minimum purchase. Many colors and gauge sizes to choose from.
Jim
Jim
I also am running current on one of my swaps and just finished a 2nd harness using their stuff on another. I would try calling them, they might make a modification for what you need or suggest something. They have always been helpful.
Rod, I have just the thing for you to use. I'm currently building the same thing you are wanting to do. I haven't ordered these parts yet but will be soon. If you can design your own electrical circuit these may be the way for you to go. I'm short on time right now so I can't type it all out but look into Cooperbussman. Here is a link to their product catalog.
cooperbussman link
They make a panel called RTMR (rear terminal mini fuse and relay) You can set it up multiple ways but they make one that you can use 10 fuses and 5 relays in. I will be using this in addition to a Power Relay Module.
RTMR
Waytek has the stuff to order.
http://order.waytekwire.com/products...%20Protection/
BJ
cooperbussman link
RTMR
BJ
cooperbussman link
RTMR
BJ
cooperbussman link
RTMR
BJ
