2nd gen camaro oil pan?
I started out with a hummer pan on my 72, but because my car is lowered AND its a street car, I didnt have enough clearance to feel safe. I changed up to the F-body pan and love it! My subframe crossmember sits lower than the pan now. Using the BMR mounts, I didnt have to notch or fab anything to change pans.
The F-body pan would give you the best ground clearance. You can also go with either the MAST or Holley pans.
You can also go with one of the Steel pans. Auto Kraft or the Champion pan are common ones that people use. This might be better if your Drag Racing, as I think the internal Baffles are better designed.
What BCZee said. Good 'ol GM works perfectly. (cheaper too)
I have an 80 Z28. I used the truck pan that came with my engine and sliced the bottom off. Then i bought a piece of 1/4 inch aluminum plate and had it tigged to the bottom of the pan. Also included a bung to put a plug in to drain the oil. IIRC i cut about 2 3/4 inches off the pan. Then i cut the aluminum close to the pan shape and had a friend tig it for me. works great. Holds about 5 1/4 litres of oil.
1 Post
I used BBC frame stands and generic E-bay 1" setback swap plates. (all block/motormount holes are inline) and Fbody pan. You can use SBC frame stands with CarShops' 1" setback plates.
I used the transdapt mount plates (non 1" setbacks) with my ls2 and the F-body pan. I've got great pan clearance with the subframe and didn't have to to any cutting. With the 4L65e I used the stock X-memeber, just had to move it back some, drilled 2 new holes & used 2 existing holes
