OBD2 not working
Blue pin 58 to OBD2 pin 2 showing ~0.4v fluctuating
OBD2 4 & 5 grounded
OBD2 16 is hot at all times (run through silverado fusebox)
Engine starts up and appears to run fine. However, when I hook my ELM 327 up it says failure to detect protocol. I'm confused why it doesn't work.
Any ideas?
-Nick
Is that ELM 327 a Bluetooth device ?... I heard that some of the eBay ones may or may not work all of the time.
Might try a cabled Scanner to verify if you are getting Serial data or not.
BC
The pcm was tuned by wait4meperformance. I told them to remove VATS. Could that have caused the serial data issues? I saw in another thread that the serial data voltage should varry between 0-7v. I'm getting 0.05-0.4ish.
"The class 2 data was
at a resting level of 0 volts and was pulled high to around 7 volts to talk."
I guess my scanner doesn't like the pcm.
Thinking of ordering a PLX Kiwi bluetooth for the droid. My dad has one and likes it. However, I would like hptuners so I can play with things.
BC
