boosted 5.3 airboat
Old 03-18-2012, 01:21 PM
single digit dreamer
parish8's Avatar
Default boosted 5.3 airboat
i am helping a guy with his airboat.
so far cam only 5.3, billet wheel 76, 66mm wg, stock computer, big injectors, e85, holly 1800hp twin pump.
i dont know anything about airboats. i do know something about ls motors and this thing should make some power. not sure if that will translate into a crazy fast boat or not. it will likely get a larger built motor down road. we are sizing everything for ~1000+hp.
Old 03-18-2012, 10:32 PM
TTLS1GP's Avatar
Cool project!
Old 05-13-2012, 10:11 PM
parish8's Avatar
it is pretty much done. should be tuning it by next weekend.
Old 05-14-2012, 08:37 AM
chevellepowered's Avatar
awesome.. def get some vids of it out on land and water... i will be doing same build for airboat soon .. love it..
Old 05-14-2012, 12:08 PM
oange ss's Avatar
holyyyyy **** !!
Old 05-14-2012, 09:41 PM
pbj-tj's Avatar
More pics and vids please
Old 05-16-2012, 09:41 PM
parish8's Avatar
moved it over to the tall side of the garage and finished it up. blades and all. tomorrow we load it up and take it someplace out of the way to tune it as much as we can on the trailer. if there are no issues it should be hitting the water this weekend.
the wg spring is 10psi. it will get turned up later but for now that seems like a good starting place. here is a short video of it in the garage.
http://youtu.be/urL4D_dIcIw
Old 05-16-2012, 10:13 PM
rotor vs. piston's Avatar
Are those G8 manifolds?
Old 05-17-2012, 06:27 AM
parish8's Avatar
yep. vband welded on, ground clean and coated.
Old 05-17-2012, 07:22 AM
RedRocketZ28's Avatar
That's awesome. In for of video of this thing in action.
Old 05-18-2012, 04:31 PM
hell yeah me too.. cant wait
Old 05-18-2012, 11:06 PM
parish8's Avatar
http://youtu.be/l_iXwqfA71Q << still uploading
got it 99% tuned. it will be hitting the river tomorrow if the weather is decent.
ran it up to 10psi and pitched the blades to hold it at 5000rpm. it moves a lot of air and makes a lot of noise.
i nearly blew it up, i had the boost line to the wg hooked to the wrong port. one of the first tuning pulls where i got it into wot the boost shot up from 8psi to 30psi in an instant and it wasn't done climbing. my hearing was not normal for 1/2 an hour after that. luckily it has good fuel and had a ton of fuel programed in and had no timing programed in. that being said i think the motor would hold close to 30psi but not till later in the year when he is ready to turn it up.
Old 05-19-2012, 12:04 AM
ls1_chevelle's Avatar
I love the donkey **** downpipe LOL
Old 05-19-2012, 07:19 AM
Bumpin' Yota's Avatar
Prop wash a bit much for the camera man? LOL!
I would NOT stand behind that period...all sorts of flying debris wind up implanted in ones skin!
I also have a feeling this airboat is going to be retardedly fast....
Old 05-19-2012, 08:05 AM
LS1TECH Sponsor
Jon@BruteSpeed's Avatar
That is a cool project!!
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
Old 05-19-2012, 08:04 PM
formerly 2000blackcamaross (6-25-2013)
LSGUNSS's Avatar
In for video of this thing in action
Old 05-20-2012, 06:04 PM
parish8's Avatar
vid is uploading. it is kinda long >> http://youtu.be/m4Cn9wGhaMg
had a fun day. boat ran great. plenty of power. the tune didn't change at all from the trailer to the water.
the boat pushed the front end down too much when you hit it. today they are going to adjust the engine/blade angle compared to the hull. that is suppose to help keep the front up. if you go too much angle the front end bounces so you have to find the sweet spot.
the boat also had a wicked lean when you floored it. i think the really high hp boats have 2 sets of counter rotating props to stop this. maybe adjusting the engine angle and getting the front of the boat up a little will help? there is another 300+hp left in this thing so the lean might be a problem but right now it is just weird but you get used to it.
Old 05-20-2012, 06:53 PM
Chicago TDP's Avatar
Not to rain on the air boat parade but you might want to let that motor run a little prior to shut down. With the load and length of run time, that turbo must be getting mighty warm and you might end up baking that oil in turbo without a few minutes of cool-down.
Super cool project though.
Takes me back to the days of building then down in southern Florida.
Back then, no one even knew what a turbo really was, lol.
Old 05-20-2012, 07:00 PM
parish8's Avatar
yeah, i will mention that to the owner. giving it 1/2 a minute to cool cant hurt.
Old 06-06-2012, 08:48 AM
It looks like the air boat is continuing to build speed in each case when yall lift off of the throttle. It also appears that at idle it's moving pretty well across the water? Yall get a gps unit to measure speed?
Any new updates?
Quick Reply: boosted 5.3 airboat
