Who sells AJE Crossmember for Fox LS swap ?
I am looking to buy the AJE cross member, a arms, Headers, and caster camber plates. Is there a sponsor on here who sells all of this or should I just buy from summit. Does anyone know the proper part #'s if I order from Summit ? Thanks
http://www.ajeracing.com/MustangCompleteKits.php
i bought mine from them directly...headers i plan to purchase 351w long tubes for the fox chassis with 1 3/4 primaries and cut the primaries flange off and weld on flanges for the ls
Sounds nice...only considering factor to me will be tranny k member...unless you can adjust engine mounts or kfor member to compensate the difference...but its possible your jw housing has the difference designed into it..idk
If you decide not to alter tranny mounting location to keep same driveshaft length and such... good alternative to engine placement is using adjustable engine mounts like from www.dirtydingo.com
have friend that uses a set and solved alot of figment issues with his engine/tranny combo
Just throwing some other info out there hope its helpful
Found out aje has a tranny k member for c4...
simple now...aje #s
k member- mu-40um...280$
Trans crossmember- mu-7050...159$
mounts- aje30...69$
C.c. plates- mu-8000...179$
A-Arms would depend on front suspension you want to go with..stock style coil or coil over conversion..im sorry for the mishap...
simple now...aje #s
mounts- aje30...69$
You may have to cut the tubes loose on the crossmember like I did 10 years ago and never rewelded.
Team Z mounts can locate the engine where you want it fwd-aft then just weld the lsx part to the mount and it is good to go. Dave and I talked about this when I was overthere a few months ago.
It is a quick and easy fit saves a bunch of $$ on this swap.
Tim
Tim
