Can a Sanden Compressor spin the other way??
Old 05-05-2012, 07:19 AM
edge04's Avatar
Default Can a Sanden Compressor spin the other way??
Long story short, I need to flip my a/c comperssor so that the clutch end faces the engine. This of course would cause the pulley to spin the opposite way, will the compressor still work? If not, is there a way to change it, maybe electrical? Didn't some corvettes come with reverse drive systems, wouldn't they need a compressor that spun the other way, or was that just the water pump? Thanks
Old 05-05-2012, 10:22 AM
oldngray's Avatar
Default direction
Call Vintage air, they if anyone would know the correct answer.....
Old 05-05-2012, 11:05 AM
edge04's Avatar
I think I can switch the lines so that it pulls and pushes correctly but not sure if the motor will run and be oiled properly. Will call them and Sanden Monday
Old 05-06-2012, 12:26 AM
i r teh noobz's Avatar
Perhaps you could grind the pulley smooth and run the belt on the outside so it runs in the normal direction?
Depending on the valving inside, it may not work correctly spinning in reverse.
Old 05-06-2012, 12:34 AM
edge04's Avatar
apparently if it is a swash palte compressor, it will work in either direction. Need to confirm with Sanden.
Old 05-06-2012, 06:51 AM
Old Geezer's Avatar
Don't think so... 2 different size lines....
Old 05-06-2012, 06:57 AM
edge04's Avatar
well couldnt i just make new lines? i have to anyway tomove the compressor
Old 05-06-2012, 05:36 PM
edge04's Avatar
in doing research, looks like my SD7 only rotates clockwise but they do make ones that rotate counter clockwise, so if I can't find a compressor about 2 inches shorter than my 508, I will have to buy one of those. Anyone know the length of the CTS-V compressor?
Old 05-07-2012, 11:07 AM
edge04's Avatar
spoke with Sanden, it will work in either direction, will just have shorter gear life running in counter clock wise rotation.
The following users liked this post:
phy6 (03-06-2023)
Quick Reply: Can a Sanden Compressor spin the other way??
