LS motor in 53 Chevy 2 door.
I am in the process of putting a 5.3/4l60e in a 53 chevy for my 14 year old daughter, having trouble finding exhaust manifolds that stay in tight enough to to motor. Also wondering which way to go about modifying harness, should I do the whole fuse and relay or do I rig it up with the 4 wire setup? And lastly any way possible to use the factory gauges and speedo or are there any aftermarket gauges that will work with the wiring harness wires? Alot of questions I know but any help appreciated.
Post up some pics if you have any. I'm planning on putting a 6.0/700r4 in my 1953 Chevy hardtop. I still got some parts to get before I start the project. I'm putting a carb on mine for ease of install. Did you install a Mustang II or are you using the stock front end?
Steve, check out my post #6 here with pics. I used the Sanderson CC1LS1 block hugger header. See their LS1 headers here. The type of steering you use will also determine what pipe you need on the left side, mine worked better with the 'center dump' type of pipes vs the 'rear dump' type (notice the difference in my pics). Hope this helps.
I bought Hooker's ceramic coated cast iron manifolds for my LS2 because they fit inside the frame rails of my 39 Chevy. They may not be the best for max hp but would be fine for a 14 yr old daughter. Raw cast iron for $300.
wiring
If you have plenty of free time and know how to chase wires and schematics, build your own standalone.
If money is not an issue buy a stand alone harness.
If you like to keep it simple and have room for the factory fuse panel go that route, that's what I did for two swaps, a couple wires and your up running.
Epay has some cheap LSX shorty headers coated or stainless for cheap...
LS1Tech Sponsor
What year is the engine that you are using? Are you going Drive By Wire or Cable? We can help with the wiring if you decide to go standalone.
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
The third pic you posted would work perfect for the steering and motor mounts we used, do they have a number for each side, can they be mixed?
We will try and get pics up soon. I went with a stock front suspension, but added a fatman 2" dropped spindles with power disk brakes and a berretta I think power steering rack.
The motor is out of an 03 Tahoe, is drive by cable. I have all the factory harness and computer still intact, next door neighbor is a GM mechanic he wants me to keep everything seperate, says it will be better down the road troubleshooting, makes sense to me so we are going his way, specially sense he's going to do it all.
Still no one with any thoughts on gauges? Thought that would be the easiest one, lol.
LS1Tech Sponsor
Regarding the gages, most new aftermarket gages are configured to work with the LS electronics. Some may require a step up circuit or playing with parameters in the PCM to function but that is easily performed.
Jon
PSI
Jon
PSI
__________________
Ebay Store
Ebay Store
