1993 Toyota 4X4 Turbo LS1
Old 09-19-2012, 07:01 PM
zapp168's Avatar
Talking 1993 Toyota 4X4 Turbo LS1
Drove it home tonight!! Not bad for a 6 lb spring. All the gauges and cluster lights work! AC all wired in just need to make lines. Little cleaning and some wire tucking (and a 10 lb spring)and off to the painter!!
Old 09-19-2012, 07:02 PM
y5mgisi's Avatar
Awesome! What did you do for a radiator?
Old 09-19-2012, 07:15 PM
zapp168's Avatar
BE COOL has a custom aluminum radiator for V8 swaps. Not sure how well it will be in 95* weather with the AC on though
Old 09-19-2012, 09:42 PM
91RS99z's Avatar
This is awesome my brothers gonna crazy jealous he wants to turbo his 6.0 swapped 85 so bad but its not really ideal for rock crawling. More details on your set up please. It looks stock width?
Old 09-19-2012, 10:54 PM
rotor vs. piston's Avatar
Nice to see another yota here, though mine is only 2wd.
Old 09-19-2012, 11:21 PM
zapp168's Avatar
Stock width? You mean the truck? Yes it is stock width. LS1 with 4L60 and NP transfer case. I had to make a shifter for the transfer case.
The turbo is a Garrett and I am running 60# injectors. The drive shafts were simply GM on one side to Toyota at the ends.
Old 09-19-2012, 11:28 PM
zapp168's Avatar
"Rotor vs. Piston" ha ha....You will hate my other car 87 RX7 LS1 5.7 6spd....Piston wins....lol
Old 09-20-2012, 12:18 AM
91RS99z's Avatar
Yeah i was asking about the axles. How long you think theyre gonna live behind that?
Old 09-20-2012, 12:55 PM
beach cruiser's Avatar
Awesome! I have a 99 4Runner that I've been wanting to do a 5.3 swap on so bad, details please!
Old 09-20-2012, 01:33 PM
zapp168's Avatar
I had a 98 Toyota truck with a SBC 400 cam, intake, headers, and I beat the hell out of it for 6 years. I only broke it once.....trying to pull a BIG boat out of the water I got BAD wheel hop in the sand even then I just chipped a tooth on the pinion and I still drove it. It is after all an 8" diff with 4 Pinions and 31 spline axles.....Stronger than the F-body the motor came from......But time will tell.....
Old 09-20-2012, 01:42 PM
zapp168's Avatar
4" Suspension lift and 2" body lift make fitting things easier. I used a combination of a LS1 to SBC motor mount conversion kit and my own fab work to mount it in. 4l60 transmission with NP transfer case from 80's full size blazer Toyota cross member notched on one side to accommodate the front drive shaft. 3" spacers from the cross member to the transmission mount. Sanderson swap headers 02 PCM and harness, just wire like any other swap.
I am sure there is an electronic transfer case that could be used I just happened to have this one, thus I had to make the shifter for it. The drive shafts I simply took measurements and took 4 drive shafts to a drive shaft place. Front and rear from Toyota and Blazer.....Made 2 Custom shafts using the shaft ends. Turbo was a blown up STS turbo, had it rebuilt and installed it by making custom exhaust and pressure pipes. Any other questions feel free to ask....
Old 09-20-2012, 01:49 PM
91RS99z's Avatar
Are the headers long tubes or just shorties?
Do you drive it on the street or wheel it? If so what kinda wheeling?
Trucks nice man i like it a lot
Old 09-20-2012, 07:32 PM
zapp168's Avatar
Shorty headers, they fit and are better than long tubes with the turbo. I honestly got it registered less than a week ago, I am still seeing what is going to break...LMAO I love wheeling, and I will do some before I paint it...after I paint it I hate getting it scratched in the woods. Thank for the compliment...
Old 09-25-2012, 01:29 AM
pairof69s's Avatar
man it would be really cool if ya could get a video of this thing wheeling around.
Old 10-07-2012, 09:50 AM
zapp168's Avatar
Old 10-07-2012, 10:04 AM
zapp168's Avatar
Old 03-28-2013, 06:08 PM
zapp168's Avatar
Default Update!!
Paint done, so is truck, I ordered rims and tires.
Old 03-28-2013, 09:08 PM
1CAMWNDR's Avatar
That is just badass. I will be interested in seeing how well the axles hold up. Might want to snorkle that intake for the turbo. I would love to have one like this only without quite so much lift. Can't see real well, but is it still IFS?
Old 04-01-2013, 08:19 AM
1CAMWNDR's Avatar
Nevermind, I can see a little bit of A-arm on a couple of the pics. So I will be fascinated to know how the frond diff and axles especially deal with some serious 4x4 launches.
What kind of wheels and tires are on the way??
Old 04-01-2013, 10:44 AM
kmattinson67's Avatar
Guessing you used a passenger side drop NP241 transfer case? What did you do for the VSS sensor. And did your mechanical Speedo cable for your Speedo hook up to the case? Doing a similar swap on an Isuzu trooper soon.
Quick Reply: 1993 Toyota 4X4 Turbo LS1
