Re-work my harness
Old 09-19-2012, 07:33 PM
souljaboy9768's Avatar
Default Re-work my harness
I'm pulling everything this weekend if weather permits out of the 02 camaro
Ls1/t56 and putting into the 68 camaro.
Question I have is (I probably asked already) but can I jut get the harness in the 02 camaro and have it re worked?
I don't have a harness at all in the 68 camaro.
I have a 12 circuit universal that I can install for from HOTROd wires.
If I got the rework done to factory harness will it be hard to tie in to 12 circuit harness??
Just curious to what my options are and if there is any threads on this .
Thanks guys!
Old 09-19-2012, 08:42 PM
aknovaman's Avatar
You can save some bux by reworking your 2002 harness. If it is a really nice
car I recommend a new harness. Just depends on if you have the skills and time to work your original harness. Just because it is old does not mean it is junk. There are plenty of vendors but some don't use gm color coded wires so in the future it may be a pita to troubleshoot.
I had a guy bring me a 57 Chevy that was drive by wire and the pedal did not work. His harness was wired wrong, it had a drive by cable only PCM (lacked the drive ic for dbw). Plus nothing was gm color coded, royal pit. The commercial company was from Arkansas.
Another national company had wires in the wrong connector holes and another two harnesses had bad crimp connections so the wires fell out and made horrible intermittent connections. So just because it is new does not make it good.
Old 09-19-2012, 08:53 PM
Who would reccomended, I hate to go cheap route and then pay for it in the long end
Old 09-19-2012, 09:22 PM
bczee's Avatar
The 02 harness is pretty easy to convert to a stand alone harness and should be easy to inter grade with you new universal body harness.
You can either strip out everything not needed and add the required wires (battry power, sign battery, fans, fuel, relays, etc) or you can intergrade via the Cxxx connector. IMO, strip every thing out, it makes a cleaner engine bay.
Suggest you research in the FAQ on the pin out and wiring harness.
If you want to pay or buy one, check the sponsor or internet, but many on the forum use Speartech or PSI.
But do you're research by reading some of the projects threads or the FAQ's
BC
Old 09-19-2012, 09:34 PM
aknovaman's Avatar
Uhm the two commercial companies have been in business for almost 30 years but you will be hard pressed to find and posts on the Internet about them. Pm me for details if you want.
Old 09-19-2012, 09:41 PM
darren roar's Avatar
I had a fellow on here do mine his profile name is Chrome_Rust. He did a good job for me and he kept in contact with me. I haven't talked to him since all u could do is shoot him a pm.
Old 09-19-2012, 11:22 PM
Thanks for the help
Old 09-20-2012, 02:15 AM
andysfbird's Avatar
i have the re-worked harness for my 67, and can take pics for you b4 i put it in if you like. What are you doing for gauges?
Old 09-20-2012, 02:04 PM
LSCha0s's Avatar
I redid a 99 harness. It sounds complicated but it is almost stand alone as is. I pulled it completely apart and re routed all the sensors/connectors I would need and took the others out. I took the rear 02s out EGR and a few senders. Once that was done all that was left was FP, Fans, Ignition/switched 12V and constant 12V. The grounds were left alone and just grounded to the back of one head.I also used a 4l60E in my swap and the PCM will control it too..Bonus
Pocket has done some great DIY tutorials on the subject.
One of the things that turned me away from having someone do it for me was the number of swaps I have seen where people end up having to diagnose a harness that was made for them by someone else. At this point I know more about my harness than I care to acknowledge.
Here Is my Engine on a stand all the connectors I was keeping plugged in and rerouting the wires.
Old 09-20-2012, 04:40 PM
Chrome_Rust's Avatar
Thanks Darren! I am still around. I can do your harness for you. Shoot me a PM. I will give you my number and you can call me or what not.
Charlie
Old 09-20-2012, 07:46 PM
Not sure what I'm doing for gauges, I would like to run factory gauges.
Old 09-20-2012, 07:50 PM
Andy keep me informed of pics and what your doing. Our install ls1/t56 should be close to the same.
Are you re working a harness? Aftermarket?
Where you mounting the PCM?
Old 09-20-2012, 08:03 PM
Andy do you have a build sheet?
Curious to know what you used for master cylinder and what other times you need for t56 install
Old 09-20-2012, 11:15 PM
ssduane's Avatar
Doing a harness is pretty easy honestly. It does have some benefits because you learn where wires goes and what they do, and down falls because, well, its a lot of work. Here is a picture of mine, tailored to a Painless 18 curcuit harness, added 5 feet to the plugs so I can put the PCM under the front seat.
And I learned more than I wanted to when I bought my eng/trans from a wrecking yard. Being new to these back then I thought I was getting a 00 LS1/trans and PCM/harness, but after gettign it home and figuring everything out I had a 00 eng/trans, a 98 PCM and a 01 harness for a manual trans, talk about a learning curve.
Old 09-20-2012, 11:17 PM
What was the cost of the painless? That's exactly what I need
Old 09-20-2012, 11:18 PM
I'm willing to do my own harness just don't know where to start
Old 09-21-2012, 01:08 AM
i r teh noobz's Avatar
lt1swap.com has pinouts.
I did mine on the car. Just take it one wire at a time. Cut, route, solder, heat shrink, repeat. Take lots of notes for future repairs - you won't remember where that solder joint is in 5 years when it cracks.
Take it one wire at a time and its simple. If you look at the whole job at once if will feel very difficult.
Old 09-21-2012, 08:33 AM
LSCha0s's Avatar
Yup.. its like looking at a road map.. You don't drive down all the roads at the same time wiring is the same one wire at a time.
Old 09-21-2012, 08:47 AM
ssduane's Avatar
Pin outs here too https://ls1tech.com/forums/conversio...swap-faqs.html
I used this website too, good info from a member here. http://www.blown.net/cars/camaro68/
The painless kit was sitting in a box in the trunk when I bought the car, so not sure what they cost.
Old 09-21-2012, 09:32 AM
the_merv's Avatar
It's pretty easy..I do all mine aswell as others.
Quick Reply: Re-work my harness
