2002 Firebird V6 to LS1 Swap - No power to Starter Solenoid
Turn ignition, all gauges illuminate, manual fan switch and other switches work BUT no crank.
Grounds are good
Battery is good
Nuetral Safety Switch is good
VATS is deleted from PCM
Why am I not getting power to the stater solenoid?
Grounds are good
Battery is good
LS1Tech Sponsor
reserved, Im looking through the diagrams for you now.....
Check white connector C220 cavity J. It will be a yellow wire with a black tracer. This is the body control module theft deterrent starter enable control. Just like I thought it does not matter that you had the vats deleted from the pcm, its the bcm that is not enabling the starter relay.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
1-888-467-4491
