Stock clamshell mounts too large for Trans-Dapt 9525
Old 12-14-2012, 04:38 AM
E_S
E_S's Avatar
Default Stock clamshell mounts too large for Trans-Dapt 9525
Hi,
I'm having a problem. I bought the Trans-Dapt 4592 motor mount pads, but the standard SBC clamshell mounts are *far* too large for the pads to fit over. The "gap" on the pads is a little over 1" too small to fit over the mounts.
Clamshell mount on the left, Trans-Dapt pad on the right. You can clearly see the difference.
What is going on and what do I need?
Attached Thumbnails Stock clamshell mounts too large for Trans-Dapt 9525-motorfester.jpg
Old 12-14-2012, 04:52 AM
E_S
E_S's Avatar
Is this something I could use instead of the 9525 mount pads, together with stock lower clamshells and the 4572 adapter plates?
http://www.ebay.com/itm/Small-Block-...51172483668%26
Old 12-14-2012, 05:22 AM
E_S
E_S's Avatar
I did some additional homework:
The clamshell style mounts are the "new" way of mounting the engine. The Trans-Dapt mount pads are made for the "old" style motor mounts.
With mounts of the same design as seen in my post #2 bolted to the Trans-Dapt adapter plates and with the clamshell mounts installed in the car, it *should* bolt up. I see people are having problems with having the mounts line up correctly, but I guess that's close to unavoidable when "mixing and matching" from all ranges and years..
Old 12-14-2012, 06:08 AM
oldgoat69's Avatar
What is the engine going into? This may also shed some light for you.
Old 12-14-2012, 07:01 AM
E_S
E_S's Avatar
Going into '89 Caprice. The B-body frame was more or less the same for the "boxy" and the "round" Caprice, all the years from 1977 to 1996.
Old 12-14-2012, 07:09 AM
6t7gto's Avatar
I used what you show in post #2 for my 84 monte carlo.
lined up perfectly.
david
Old 12-14-2012, 07:16 AM
E_S
E_S's Avatar
Thanks! I grabbed a pair cheap off Ebay (cheaper than the ones I linked to) today, so then I just have to wait until they show up and see how it works.
Quick Reply: Stock clamshell mounts too large for Trans-Dapt 9525
