Needed reverse lock out solenoid on T56 trans
Old 01-27-2013, 07:04 PM
alaninin's Avatar
Default Needed reverse lock out solenoid on T56 trans
I noticed my reverse lock out solenoid was broken when I started to connect my T56 transmission. Would anybody happen to have one that has deleted the reverse lock on there build? If no one has one where would the cheapest place to purchase one?
Thank you for any help.
Old 01-27-2013, 07:21 PM
Nsty98LS1's Avatar
I would just plug the hole & be done with it.
Old 01-27-2013, 07:30 PM
alaninin's Avatar
I have done to much work on the trans tunnel to keep it. I would hate to plug it now I have the room for it.
Old 01-27-2013, 07:49 PM
bczee's Avatar
If you can find one, I would use it.. chances are you mingh never miss shift it into reverse (4-5 or 6-5, but it is cheap insurance.
good luck finding one.
BC
Old 01-27-2013, 08:13 PM
85MikeTPI's Avatar
New from a Sponsor
http://www.tickperformance.com/treme...kout-assembly/
Might find a used one posting in the classifieds and in the Manual Trans forum.
Old 01-28-2013, 05:47 PM
130fe's Avatar
Thumbs up
I bought one from Tick, great to deal with!
Old 01-28-2013, 05:50 PM
REDL1NE's Avatar
haha, I was just about to suggest them. I was looking for a master cylinder and ran across this.
Glad you found one!
Old 01-29-2013, 05:26 AM
alaninin's Avatar
I would like to find one for $50 or under shipped. There must be someone out there that could help me out with my build and sell me a reverse lock out solenoid.
Old 01-29-2013, 08:32 AM
gofastwclass's Avatar
I've found tick to have a bit more markup on some parts than other people.
You may give D&D Performance a call, all they do is manual transmissions. I looked their site over and didn't see it, but they may still have access to them because not everything they have is on the site for some reason. The knowledge and service from the guys at D & D is top shelf. ...and yes, they are a sponsor.
Old 01-29-2013, 11:03 AM
nuckifuts's Avatar
What kind of time do you have. I do not THINK i can use it with my car so i may sell mine but am not 100% yet.
Old 01-29-2013, 04:42 PM
alaninin's Avatar
It is holding me up now the sooner the better.
Old 01-30-2013, 03:52 PM
alaninin's Avatar
Anyone have one hanging around in there garage that they want to get rid of? Just trying to avoid spending $100.00
Old 01-30-2013, 05:38 PM
91 240's Avatar
i should still have mine. i'll check when i get home tonight and let you know
Old 03-18-2013, 03:18 PM
dre2013's Avatar
i need one too..if anyone has one please send me a pm
Old 03-19-2013, 01:20 PM
waterhook1's Avatar
I have a ls1/t56 swapped into a TR6 Triumph. I didn't have much room for my Reverse Lock out solenoid by my leg. So I cut the aluminum housing in a way that I was able to use the piston and spring to lock out of reverse with strong spring tension. I just have to crash force it into reverse. I tig welded a cover back on where it was cut from the housing. It works great without all the bulk being in the way. I still have the solenoid but not the housing for it. It looks like a block off cover when all said and done. I think I cut down the piston a little for it to work.
Just another way to deal with it!
Quick Reply: Needed reverse lock out solenoid on T56 trans
