Radiator Hose Question - Radiator Swap
Old 02-26-2013, 10:22 AM
PWagon's Avatar
Default Radiator Hose Question - Radiator Swap
I am putting a 5.3 LS engine and a Griffin radiator into my truck. The Griffin radiator has both coolant inlet and outlet on the passenger side of the vehicle. I'm having a hard time finding the right top hose for this setup. Do any of you know the part number for this hose I need?
Old 02-26-2013, 11:02 AM
krwyellowZ28's Avatar
Wish I could help you out, but I'm about a week away from addressing the same question with my Affco dual pass radiator. I'll be watching to see how other guys respond.
What lower hose did you use?
Old 02-26-2013, 11:03 AM
Prorac1's Avatar
Your best bet is going to be to make a template of the shape of hose you need, and go to an autozone, or the like, and find one that matches. Thats what I did with mine, and I found some hoses that fit and were designed exactally the way I wanted. Good luck on your search. Eric L
Old 02-26-2013, 01:21 PM
oldngray's Avatar
Smile hose
X2 on prorac, your other option is to get stainless mandrel bends and make it for your needs with a short hose part on each end....welding required..
Old 02-26-2013, 02:39 PM
fox12303's Avatar
Speedway and Jegs sell aluminum hose connectors. Use the truck upper hose for ends and connect the two together with the aluminum couplers. Napa sells flexible hose in differant lengths and diameters too if you don't mind the appearance.
Old 02-27-2013, 02:09 AM
01cherryreds10's Avatar
I think for my car the top hose ended up being from a Cavalier with a quad 4, lol. I also have a dual pass radiator
Old 03-08-2013, 02:44 PM
Any more ideas on this or part numbers? The guys at oRielly's let me search their wall of radiator hoses and I came up with nothing useful. I might have to buy a hose the right size with the right bends and then cut/splice with a nipple to get the shape right.
Old 03-08-2013, 03:34 PM
PWagon's Avatar
Thumbs up Radiator Part Numbers...
I read somewhere (too many forums to keep straight) anyhow, I read somewhere that the part numbers are as follow. The lower hose is a Goodyear # 60867 and the upper hose is a Goodyear # 61331. Yes, I end up answering the question to my own post.
Old 03-08-2013, 03:47 PM
Just going off the google images those look like they could work. You definitely helped me out, even if you did find the answers to your own question. Thanks a ton!
Old 03-08-2013, 06:51 PM
BobKovacs's Avatar
Can't help with that application, but I just put the same radiator in my '69 Camaro today. Took the guys at Autozone all of 10 minutes to find hoses that worked perfectly with my coat hanger templates.
Old 03-08-2013, 08:45 PM
Got the part numbers handy?
Old 03-09-2013, 05:42 AM
BobKovacs's Avatar
Dayco 71500 and 71796. The lower only uses half of the overall hose, so don't be surprised by how big it looks when you see it.
Quick Reply: Radiator Hose Question - Radiator Swap
