BMW e34 Touring LS1 swap (BMW 5 series wagon)
Old 03-05-2013, 01:13 PM
Sparkydog's Avatar
vazfx16 - coach me on how you did those photos ^. I am an old dog and I want to learn new tricks!
Thanks!
Old 03-05-2013, 01:15 PM
SWAGON's Avatar
Yeah, those design illustrations are the bees knees!
Old 03-05-2013, 02:11 PM
mckchr67's Avatar
Looking good. Subscribed!
Old 03-05-2013, 02:21 PM
vazfx16's Avatar
Originally Posted by 1970 ls_c10
interesting car for this swap! want to see it finished!
This will be my Daily Driver, so it must be finished
Old 03-05-2013, 02:26 PM
vazfx16's Avatar
Thanks!
It is easy if you have photoshop:
1. Use tripod (to keep this in alignment)
2. Photograph the object (in this case a crossmember)
3. Change wait you want in with the subject (I added the oilpane)
4. Photograph
5. Bring into Photoshop and add both images to the same document
6. Have a layer of each image
7. Reduce opacity on the image that you want to ghosted out
8. save as the format you want
9. I then drew the red bracing in with Illustrator, but it can be done in Photoshop to, just a bit more work to draw in and stroke
Old 03-07-2013, 08:20 AM
LQ4-E39's Avatar
See, and you were saying how tough it is to document a build as it goes…
It comes naturally once brain gets sucked into the “tornado” of the project (always seems to be in the back of your mind).
Old 03-07-2013, 05:57 PM
vazfx16's Avatar
Your right. The big thing is to take the camera out to the garage with you. I am finding that taking lots of shots will help my memory also.
Thanks for the encouragement.
Old 03-07-2013, 05:59 PM
vazfx16's Avatar
The next thing I think I realize I may be able to do is to use the BMW ac compressor. I have not tried to fit the LS1 pulley yet, but that is next. If I can do that it will save some time on dough on getting ac lines made. I can then make my own PS lines.
Old 03-10-2013, 12:32 PM
vazfx16's Avatar
I made a metal yard run yesterday, so I am ready to start making hard parts.
I maybe be able to do the first test fit today. Yesterday was spent on GTO oilpan swap. Sounds easier that it was. Photos to come.
Old 03-10-2013, 04:03 PM
brewster240's Avatar
come on over to silviav8.com, there are a few front sump pans we have figured out cause the 240sx uses them too.
somewhere there is a thread with comparisons.
Old 03-10-2013, 10:28 PM
vazfx16's Avatar
Will do
Old 03-10-2013, 10:38 PM
  #32
vazfx16's Avatar
I am surprised how clean and fresh the inside of the pan was. Lots of clean oil too.
About to do the first test fit. LS1, meet BMW E34 5 series Touring.
Consummation of a long relationship to come.
Wait! The stock mounts and manifold wants to occupy the same location as that giant steering box. Next, I need to remove the motor mounts and driver's side manifold then see how much space I have, then I will start making things.
Old 03-10-2013, 10:51 PM
  #33
vazfx16's Avatar
BMW m60 compared to GM LS1. I am surprised that they are so close in size. I was under the impression the the LS1 would be quite a bit smaller. Based on research, the LS1 is 40lbs lighter than the BMW M60. A rough measurement says that the M60 might be about 2 inches longer and about 2 inches wider.
Old 03-11-2013, 12:00 AM
  #34
rathersmart's Avatar
can't wait till it's done!!
Old 03-11-2013, 07:30 AM
  #35
LQ4-E39's Avatar
Great comparison picture.
Old 03-16-2013, 11:21 PM
  #36
vazfx16's Avatar
Tight fit, but I was able to get the bellhousing to clear the rear crossmember.
Using my hightech organic measuring device to determine how low the engine must go to fit under the hood.
Using all surface to solve problems. I used some dry erase book paint on the cabinets so that I can use them a writing surface. Works well...
Here is how much I must notch the crossmember.
Here is where the notch will be.
Prepping for the brace.
Welding on he backside of the crossmember bracing. Welding under here was difficult because oil inside of the crossmember would get heated and seep out. Then the seeping oil would contaminate the weld. It took a long time to clean up the oil enough to get a suitable weld.
Notched. Now to box and reinforce, but first I must test fit the engine for a third time.
Old 03-17-2013, 04:58 PM
  #37
flashgordon's Avatar
Good work brother from another mother. Looking forward to more...subscribed.
Mitch
Old 03-17-2013, 09:20 PM
  #38
vazfx16's Avatar
The notched xmember worked
The radiator fit.
Boxing in xmember.
Xmember done. Next motor mounts.
Old 03-17-2013, 09:37 PM
  #39
red04montels's Avatar
wow amazing work here! Subbed for this one!
Old 03-17-2013, 09:51 PM
  #40
vazfx16's Avatar
Thank you.
Quick Reply: BMW e34 Touring LS1 swap (BMW 5 series wagon)
