brake cleaner tube in oil pan
I got my 5.3 in my chevelle and after adding oil i discover a few pinhole leaks in welds on modified pan so the welder said drain oil and spray brake cleaner in to clean oil oiut and while doing it the red tube came off. And went in my pan so i got another tube and it came off in it also so the question is should i pull out motor and tranny and remove pan get tubes out and have it welded or leave them in it?
wow.. not one but two ??
Try using some tape on a stick, bar, screw driver.. or something?. But don't use some small peice of tape that will rip easy or fall off....don't just put a peice on the end of the stick/bar.. I would run it the lenght of the stick so you have a peice that is still out side.. then you can pull it out like a rope.. try and hope you can move it around and hopefully the tubes will attach to the tape and then put it out. (electric or duct tape sliced into thin strips, 1/4" ?).
Or maybe a dab of grease on the stick.. something sticky.. hopefully the tube are still near the drain hole.
Just don't loose anything else in there.. ! LOL..
BC
BC
Was gonna let air dry for a week or so before welding i was spraying through the oil level sensor hole and letting it drain out the bottom and yea we were trying to weld in car i Didnt think brake cleaner left any residue after dried i knew carb cleaner did since its oil based
Ok here is my 2 cents. flush it out with varsol through the sensor hole until it floats out the drain or you can see it and pull it out. catch varsol and repeat. If this fails at least it will be clean.
Step two: follow other posters idea of tape,get a coat hanger wrap it in duct tape inside out and go fishing.If this fails.
Step three: Sit down crack a beer and say to your self how can I be so fuc@#$@%^#%@ stupid
Step 4 : drink more beer and start pullin
I feel for ya !!!!!
I feel for ya !!!!!
Plus you aren't likely to get a good weld unless you get the pan absolutely clean. Best way to do that is pull the pan and put it in a dishwasher.
Um...keep spraying in brake cleaner until you flush the 2 tubes out.....or completely fill the pan with little red plastic tubes
I can tell what's going to happen. The plastics melting point is higher than your oil will get, but it will soften them enough to get sucked into the oil pickup. It wont make it through the screen but will stick there. If it covers enough of the screen, you'll get oil starvation issues.
On marine engines, it's common to suction the oil through the dipstick tube with a platic hose. You see the ends of these hoses break off every once in a while and end up stuck to the pickup screen.
Wow that sucks, pull the pan clean and weld, next time leakcheck before you install. ty wraps work great for holding red tubes tape. stick the ty wrap through the head and tape body to the can.
Feel for YA
Feel for YA
In October 1918, Hitler was partially blinded in a mustard gas attack near Ypres in Belgium. He was sent to the military hospital, where the news of the November 11, 1918, armistice reached him as he was convalescing.
This welding warning should be a sticky on every forum on the internet. I just found out about it a few months ago but luckily have not started doing any welding learning yet.
Well ventilated is not a safe area when it comes to this brake cleaner welding because permanent brain damage can happen at a concentration down in the PARTS PER BILLION. So your garage door open with a little fan doesn't count as "safe". From what I've heard its not permanent damage like "I have trouble remembering peoples' names", but more like "I need someone to feed me because I lost control of my arms"
READ THIS ABOUT BRAKE CLEANER AND WELDING !!!
Before loosing anything else in there, try a blob of grease on a coathanger or the like....grease if lost in oilpan won't hurt a thing.
I would pull the pan and do it right.
This is why TIG welders that mess with aluminum get paid.
Have you tried a plastic magnet thru the drain plug hole???
Also I have smeared rtv on the outside porous oil pans and removed the oil cap and put the shop cav in the fill hole I made a special adaptor. . Just don't leave it on too long. . I think the spec for leaving the vac on is 30 seconds per cube on steel blocks and 20 seconds per cube on aluminum blocks
