need ideas transmission cooler location ?
Old 05-02-2013, 08:28 AM
john 67's Avatar
Default need ideas transmission cooler location ?
I bought a stand alone transmission cooler with its own fan and 180 thermostat for my new 6l80e install.Just would like to see if anyone has any suggestions or pics of their installation. I do not have room in front of the rad.Thanks for the help .....John
Old 05-02-2013, 09:19 AM
bczee's Avatar
How big is the cooler ?.. and which car ?
I've seen a few mounted on the frame outboard under the passenger door area.. would it fit there ? How about perpendicular to the back side of the lower Radiator ?
BC
Old 05-02-2013, 11:37 AM
john 67's Avatar
the cooler is about 7" x 9" by 2 1/2" at its deepest point . its for the 67 , finally got it driving this weekend ( sandy ). I will have car on a lift next week so i can better plan where it may go easier than the creeper. hope to take it on the hot rod power tour ? JOHN
Old 05-02-2013, 12:02 PM
bczee's Avatar
Great to hear you got it back on the road after Sandy. How is everything else working out..? I was in NYC during the Storm also.. some vacation it turned out to be.. LOL..
Old 05-02-2013, 03:32 PM
Doug G's Avatar
Anywhere you'll get good air flow should work.
I made a bracket for mine so it stands about 3-4" in front of radiator and attaches from core support to hood latch bracket. Been on the for 12+ years and doesn't go through the radiator at all. No issues even with the 4500 stall.
Old 05-02-2013, 05:16 PM
jimmer1g's Avatar
I was told you should plum the lines in on top to make you get no air bubbles correct me if i'm wrong
Old 05-02-2013, 06:46 PM
Doug G's Avatar
Depending on the design ???? should.
Mine is a tube bent in a series of U's with fins like a radiator, so I didn't worry about that much.
similar to this one...
Old 05-02-2013, 06:51 PM
john 67's Avatar
I bought this one
http://www.summitracing.com/parts/bmm-70298
Old 05-02-2013, 07:08 PM
Roger Mabry's Avatar
Default Have mine mounted to custom radiator support
Check out the photo...
Attached Thumbnails need ideas transmission cooler location ?-front-almost-complete.jpg
Old 05-03-2013, 06:57 PM
john 67's Avatar
Looking around underneath I am going to mount it under the drivers seat area .I will take pics when done. JOHN
Old 05-03-2013, 07:22 PM
darren roar's Avatar
I mounted mine directly to the radiator on the outside.
Quick Reply: need ideas transmission cooler location ?
