twin turbo l33 in a 85 monte carlo ss advice
Old 09-17-2013, 12:56 PM
Mt.Dew's Avatar
Default twin turbo l33 in a 85 monte carlo ss advice
Hey guys, I'd like to pick your brains about this build. Here's what I have so far..
1985 Monte SS about 3400 lbs
two Holset Hy35's ( t-3 footprint about 64 pounds per min maxed)
l33 alm blk, stock rotating assembly, 243 heads
I'm going to use the truck intake/ tb
E85 fuel
Megasquirt 2
Th400 (reverse manual-t brake)
ford 8.8 31 spline axles, carrier
The car will be a street car with weekend strip duty. Im undecided on the cam, converter and gears. I'm wanting a streetable 700 rearwheel hp car.
I'm thinking between a 3.08 and 3.55 gear, 3600 stall and maybe a tsp 224r cam. Any ideas, suggestions?
Oh, I don't care about cam surge or a lumpy idle.
Old 09-17-2013, 05:06 PM
406chvycamaro's Avatar
Id go with 3.73 gears
Old 09-17-2013, 08:09 PM
Mt.Dew's Avatar
3.73's? For a twin Turbo application? I was thinking 3.55's are a lil steep.
Old 09-17-2013, 08:18 PM
Sorry your right I was thinking naturally aspirated. My fault
Old 09-17-2013, 09:52 PM
nastylx's Avatar
Id go 3.25's personally
Old 09-18-2013, 08:38 AM
Mt.Dew's Avatar
Lol no harm.
Yeah, ill most likely use those or 3.08's
Old 09-18-2013, 08:53 AM
Mt.Dew's Avatar
Lol no harm.
Old 09-18-2013, 09:12 AM
I don't have any turbo experience but it sounds like it'll be a fun ride. Good luck with build
Old 09-18-2013, 03:32 PM
Mt.Dew's Avatar
Thank you sir.
Old 09-18-2013, 04:25 PM
S13LSx's Avatar
I'd do HX35's not HY's. The little 9cm2 T3 housing will choke like crazy with 163ci each. The HX35 has the exact same 56mm compressor wheel with a larger 12cm2 T4 turbine housing and a slightly larger turbine wheel. Twin HX40's would be the **** but they are harder to come by.
Old 09-18-2013, 08:02 PM
Mt.Dew's Avatar
I'm gonna give them a try. Lots of DSM guys run them fine and have no back pressure problems. The 4g63 is only 122 cubes but, a lot of guys rev to 8k. I myself had one on a 4g63 logging 64 lb/min.
I'm going to limit myself to a 7k redline. So, Im curious as to how they will perform. If they choke , x35's and 40's are common here. I live in the middle of a performance diesel mecca.
Quick Reply: twin turbo l33 in a 85 monte carlo ss advice
