Mustang LS swap, good place to mount PCM?
Old 10-25-2013, 09:57 PM
TDMKR496's Avatar
Default Mustang LS swap, good place to mount PCM?
Doing a 5.3 swap in a 88 mustang, where is a good spot to mount the PCM?
Old 10-25-2013, 10:08 PM
nuckifuts's Avatar
I went through the factory hole and mounted it on top of the AC box. I MIGHT have had to remove the 'fresh air' portion and made it recirculation only. Its been a long time so i am not 100%
Old 10-25-2013, 10:25 PM
soundengineer's Avatar
stock PCM's were made to be in the engine bay as they are sealed from dust and moisture...so just mount it on the firewall somewhere on the passengers side..
if you get rid of all the HVAC stuff like I did, theres plenty of room behind the dash..LOL.
Old 10-26-2013, 09:02 AM
TDMKR496's Avatar
I read this morning where a guy mounted it in the stock ford ECM location, I'll see if thats possible.
Old 10-26-2013, 01:04 PM
Swapper's Avatar
i seen where a guy mounted it under the passenger seat.
Old 10-26-2013, 07:47 PM
like I said... all kinds of room if you remove all the HVAC stuff....
a few pictures...but sorry... no stock ECU on my setup
Old 10-26-2013, 07:51 PM
TDMKR496's Avatar
Thats very nice. I'm keeping the HVAC.
Old 10-26-2013, 08:54 PM
Docked Wage's Avatar
One of my customers cut a square hole in the cowl and mounted it so the connectors are under the hood and the main body of the PCM is under the leaf screen.
Old 10-26-2013, 09:18 PM
BigEd_72455's Avatar
Biggest concern is what harness do you have?
Is it a stock harness for car or truck? Is it an aftermarket harness that has been lengthened to your specs?
Or do you have a harness and need a location to do measuring for a harness order?
Old 10-26-2013, 09:21 PM
I don't really see that happening because the ford ecu is smaller and plugs for it are in the narrow end facing up. The GM plugs are in the long side facing out.
If you opened up the area quite a bit, you could do it, but before stuffing it in there for good, I would make ABSOLUTELY CERTAIN that everything is working PERFECTLY..
Old 10-26-2013, 09:24 PM
Originally Posted by soundengineer
Say man, you need about 20-30 more connectors/lights over there, I can still see some PANEL!!!!!
That location gonna have a USB connector for plugging in a flash drive to play music? LOL
Old 10-28-2013, 03:10 PM
TDMKR496's Avatar
Well I don't believe that its going to mount in the original ECM location, I am going to see if there is room between the ac box and the transmission tunnel once I get the dash back in.
Old 10-28-2013, 10:49 PM
streetlegalls1's Avatar
Default PCM mount
Here is another option
Old 10-29-2013, 07:27 AM
TDMKR496's Avatar
This is what I am going to do. I looked at the air box and it just screws on. All that box does is diverts the intake from outside fresh air or cabin air.
Old 10-29-2013, 10:24 AM
geoff17's Avatar
That's exactly where I put mine too.
Old 10-29-2013, 10:32 AM
geoff17's Avatar
Old 10-29-2013, 11:39 AM
groundczero's Avatar
Since I was relocating the battery to trunk, I put my ECU where the battery use to be.
Old 10-29-2013, 01:04 PM
You'll loose the blower motor too
Old 10-29-2013, 01:10 PM
This seemed to be the ideal option for me using the PSI harness so i didn't have to move things around on the inside,you can hide the harness or not.
Old 10-29-2013, 01:13 PM
TDMKR496's Avatar
I like the placement of it, but I'm using a PSI harness and it doesn't have enough wire for that to reach.
Quick Reply: Mustang LS swap, good place to mount PCM?
