FIRST SWAP! LQ4 with whipple SC
Old 10-29-2013, 01:02 AM
Topshelfcustoms's Avatar
Default FIRST SWAP! LQ4 with whipple SC
Need advice/input/help.... starting my first swap in a 1972 Blazer. after talking with a few buddies seems I will be using an LQ4 bottom end with stock internals, LS3 CNC ported heads, Comp cam and LS3 intake with whipple SC (whipple is older and doesnt replace the intake manifold). I plan on building a 4L80e for trans and still have no clue on best t-case. Any advice or ideas greatly appreciated. budget is 10K on drivetrain with a lil room to fudge. hoping for 700hp?
Old 10-29-2013, 08:45 AM
conan's Avatar
Welcome... Make sure you have enough $$$ in you budget for a fuel system thats up to the task. Are you going pump gas or E85 ?
Old 10-29-2013, 12:29 PM
Hadnt decided on pump fuel or e85..... Pros/cons I know e85 is sometimes hard to find but this won't be a daily driver... What fuel system do you recommend? Stick tank? Aftermarket? I haven't figured that out yet!
Old 10-29-2013, 03:03 PM
conan's Avatar
You can push it harder on E85 vs pump gas, but if getting it is a pain I would stick with pump. Give lonnie a call and talk to him about your plans and he can recomend / sell you any thing you need. I have his dual intank pump set up and it has been flawlell, customer service is top notch too. http://www.lonniesperformance.com/
Old 12-04-2013, 02:15 AM
So bottom end is at machine shop, cam,lifters,and heads ordered.... Anyone know if the rocker assemblies from the lq4 will work on the ls3 heads?? Also picked up an np205 tcase and advanced adapters is making me adapter to bolt to 4l80e. This project is slowly coming to life!!
Old 12-04-2013, 02:16 AM
I think I will be using the aeromotive in tank fuel system. Seems to have very good reviews!
Old 12-07-2013, 03:21 AM
Got the supercharger.... Now just waiting for the engine to come back from shop
Old 12-07-2013, 03:22 AM
Down to frame.... Time to get to work before engine gets here!!
Old 12-10-2013, 01:59 AM
gnx7's Avatar
sell supercharger..... build turbo setup
Old 12-11-2013, 02:19 AM
want it somewhat streetable.... how do I start a build thread.... cant find build thread section
Old 12-11-2013, 07:11 AM
TechCam97's Avatar
This is your build thread.....
Old 12-11-2013, 10:11 AM
operatorfailure's Avatar
I second the turbo idea. I'm not sure what whipple that is but I didn't know they made a side mount one that will support 700 HP. Either way, I want to see it so keep us updated!
Old 12-11-2013, 10:13 AM
Verz's Avatar
Turbos are very streetable just have to plan the setup properly and there are plenty of vendors who can help
Old 12-11-2013, 11:18 AM
The whipple is an older unit that I believe is 2.3 lpm. It's for Chevy truck before they went to intake replacement unit. Not ideal but the price was right. E85 may be a serious decision here as well.....
Old 12-13-2013, 08:22 PM
Engine is almost ready to assemble and dirty dingo crossmember installed.
File Type: zip
Old 12-13-2013, 08:30 PM
Default still learning how to upload pics
Old 12-14-2013, 03:23 PM
Ordering heads this week and cant find much info on rocker assemblies. Found a few threads that say ls3 heads use "offset" rockers which im assuming are different than sock 317 heads. Can someone confirm this? would be much appreciated.
Looks like half rockers off 317 will work and other half are offset?
Old 12-14-2013, 03:59 PM
fast89stang's Avatar
Rockers are offset. Lq4 won't work. I believe it's the intakes. Can't remember without looking.
Old 12-14-2013, 05:58 PM
Doug G's Avatar
Yes, intakes only are off-set.
As for the T-case...a 205 is almost indestructible(gear driven)....next would be a 208 (chain driven), and/ or you could go to a "newer" style case ?
Old 12-14-2013, 06:06 PM
superdave84's Avatar
If you start a Photobucket account (it's free) you can post your pictures there and then put them here in your build thread without people having to click the little thumbnails. Pictures will be a lot bigger too.
Just start a Photobucket account, upload pics there, then click one, copy the image URL, come to this thread, click the little yellow icon in the message box, paste the URL and that's it.
Quick Reply: FIRST SWAP! LQ4 with whipple SC
