Break-in oil for turbo 408 lq4?
Old 12-31-2013, 03:44 PM
zapp109's Avatar
Default Break-in oil for turbo 408 lq4?
What oil do yas recommend for a 408 stroker lq4 turbo motor? Procedure? Miles, minutes? Id like to get the car driving around a little with a half *** tune on it to break it in
Old 12-31-2013, 05:12 PM
rotor vs. piston's Avatar
I'm a believer in red line products, would get their break-in oil additive and your conventional oil of choice. I've always changed the break-in oil ~50 miles. Always have read to run the engine ~2k rpm to break in the cam at first start up.
Would love to hear more profession responses.
Old 12-31-2013, 08:24 PM
i r teh noobz's Avatar
LS roller cams don't really need that old 2K RPM break in. Does the manufacturer of your rotating assembly suggest anything in particular?
If it were mine, I'd run cheap synthetic while it idles to operating temp. Maybe put it around the block once, then change it for whatever quality oil you plan to run for the rest of the engine's life.
Old 01-01-2014, 04:47 AM
zapp109's Avatar
My buddy thats tuning the car recommended a straight 30 non detergent oil
Old 01-01-2014, 05:17 AM
itsslow98's Avatar
Exactly what mind suggested. I picked it up at autozone and ran that for the first 150 miles. Then changed to a regular 10w30 conventional till 500miles which I then started using VR1 Racing 10w30 which is what ill likely stick with.
Definetly no synthetic for a few thousand miles. I struggled deciding between joe gibbs break in oil and all those types but settled on what my builder and then tuner suggested. I did buy WIX oil filters since they are one of the best.
Old 01-01-2014, 05:59 AM
zapp109's Avatar
Thanks for the reply, I am most likely gonna pick up some Joe Gibbs br30 sounds like its favored by many. What did you pick up from autozone?
Old 01-01-2014, 09:45 PM
itsslow98's Avatar
Autozone brand sae 30 non detergent.
Old 01-02-2014, 07:52 AM
cam
cam's Avatar
Joe Gibbs break in oil, Joe Gibbs LS oil after break in. Lots of clever builders use this stuff.
We've been using the break in oil and its been fine but im still running the Castrol 0w30 for daily use with a little bit of ZDDP added.
Quick Reply: Break-in oil for turbo 408 lq4?
