Aje a arm and k member issue
Old 01-25-2014, 06:17 PM
06Sierra2's Avatar
Default Aje a arm and k member issue
90 foxbody with aje k and aje control arms. Did anybody else have issues installing them? The k member went in with no issues but the a arms don't want to slide in. The rubber bushings won't slide in between the mounting tabs. Anybody else have a similar problem? I searched but it seems people have had the opposite problem and had to shim with washers. Obviously I could call aje but they are most likely closed until Monday and I was trying to get the install done this weekend.
Old 01-25-2014, 08:51 PM
toxic99's Avatar
Haven't put mine in car yet. Let you know when I do. But you might get an answer by then....
Old 01-25-2014, 09:21 PM
BigEd_72455's Avatar
Are you sure the bushings are all the way in the arm? Did you compare them to the originals?
Old 01-26-2014, 11:00 AM
06Sierra2's Avatar
I no longer have the originals. They seem to be pressed in all the way but I suppose I could put a c clamp on them and see if they compress some. I'll give that a shot and let u know.
Old 01-26-2014, 11:13 AM
99MUSTANG5.3L's Avatar
How far off from sliding in are they? If I recall I had to tap my stock arms with poly bushings in .
Old 01-26-2014, 11:58 AM
onequiklx's Avatar
mine were tight but i was able to tap them into place with just my hand. Fit rather good and i was happy with it.
Old 01-26-2014, 12:05 PM
06Sierra2's Avatar
There about a half inch off. I can only fit one side in. I'm gonna mess with it again later today
Old 01-26-2014, 01:26 PM
onequiklx's Avatar
just be patient with it...im sure u will be able to get it...if i rem right one side of mine was tighter than the other on each a arm. think the one closest to the firewall was a small gap but pulled up fine when i tightened it.
Old 02-21-2014, 05:21 PM
06Sierra2's Avatar
Sorry it took so long to update, I ended up hammering the mounting brackets out a little with a rubber mallet just enough to slide in. The gap then tightened up just fine. Already installed a manual rack and ordered coilovers for the setup. Not a big issue but something aje should probably fix. I also had to dremel the opening on one side of the k slightly to mount the steering rack
Quick Reply: Aje a arm and k member issue
