43 psi corvette regulator ?
Old 01-26-2014, 06:15 PM
ijimmy's Avatar
Default 43 psi corvette regulator ?
Anyone know of a regulator like the corvette that works off 43 psi instead of 58 . Im putting in a ez efi system and it calls for 43 psi
Old 01-26-2014, 07:38 PM
i r teh noobz's Avatar
I've seen similar filters on a few Ford products.
Old 01-26-2014, 08:05 PM
soundengineer's Avatar
buy an adjustable fuel pressure regulator...
Old 01-27-2014, 07:29 AM
ijimmy's Avatar
Im trying to avoid the adjustable regulator , as they seem to cost about 3 times the amount as the corvette regulator , and then I would have to buy a fillter on top of that , so it ends up being about 4 times the cost , plus Im familar with doing the corvette method , and the old adage applies , keep it simple , dont fix what is not broke
Old 01-27-2014, 11:07 AM
garys 68's Avatar
You might check what the LT1 covette, Camaros, etc used. I think the TPI ran at about 45psi.
Old 01-27-2014, 06:18 PM
The old GM stuff won't have a regulator/filter assembly.
Old 01-27-2014, 06:43 PM
ijimmy's Avatar
You are correct . I checked the lt1 lt4 , tpi regulators and they plug into the fuel rail somehow , not a separate unit like the newer vette ls regulators
Old 06-09-2014, 07:44 AM
ijimmy's Avatar
anybody familiar with wix 33409 ?
Old 06-09-2014, 10:15 AM
EFIHARNESS's Avatar
An Aeromotive clone adjustable regulator with guage can be had on line for under $30 and work well. Steve
Old 06-09-2014, 10:19 AM
ijimmy's Avatar
whats a good one to own,,,,, I have a gauge
Quick Reply: 43 psi corvette regulator ?
