1/4 mile guesses? Stock LM7 in 3,000# mustang
It's a bone stock lm7 with truck intake, a cold air intake, exhaust and tune it's going into a 3,000# full tubular suspension mustang with a th350 trans and 3.73's with radials, it will be ran at South Georgia Motorsports Park which is 242 feet above sea level, any idea of what it might run in the 1/4 naturally aspirated and with a 150 shot?
I'm thinking 12.0-12.6 with trap being around 117-123.
I'm not great at calling these but would like to see.
Your biggest deal will be getting that 60ft.
When will you run?
When will you run?
3Pedles with a ly6 and stock cam was Mid 12s but his car is a bit heavier than yours. I expect you will be about the same or slightly slower once tuned.
Mid 12's to low 13's is my guess since your using a 5.3 also he had more gear so a bit of a advantage there.
Bruce
Bruce
If it is 3000# with you in it and you can get a decent 60ft.(might be hard to do with you convertor) I say low to mid 12's and with the 150 shot, low 11's to high 10's.
A decent cam and convertor would make a big difference.
My 04 GMC pickup ran 14.6 when it was new and stock and it was a 5.3/373 truck @ 4700 pounds so basing it off that I would say between 12.9 and 13.1 na.
Between 12.7 and 11.0 on nitrous. Over the years I have seen so many good and bad things with nitrous that I have also learned that you never know what its going to run on the stuff.
