New design for aje k member?
Old 02-21-2014, 08:38 PM
Sleeperls's Avatar
Default New design for aje k member?
Ordered my swap k member from summit and noticed the design is a little different from most ive seen.
The bottom bar is square.
Old 02-21-2014, 10:27 PM
06Sierra2's Avatar
That's how mine was as well. I had problems fitting the a arms in and the mounts for the steering rack but it was very minimal clearancing
Old 03-03-2014, 04:30 PM
streetknight2's Avatar
Could you elaborate a little on the problems?
I just put one in over the weekend and the steering rack if you get one side lined up, the other bushing will not start.
On my A arms, stock ones will slide right in, but my UPR tubular A arms won't start at all, they look way off for some reason.
I have the exact same setup on my other car with no issues, so I know "it should" work. My other car has the older round tube k member though
Old 03-03-2014, 09:13 PM
Sleeperls's Avatar
The older tube style where better imho.
My a arms are aje and they where tight to go in. I dont have a manual rack yet to try the rest. The tubes that hold the rack slid right in.
Old 03-05-2014, 05:04 AM
onequiklx's Avatar
mine is square tube and everything went on just great with no problems. used aje a arms and manual rack.
Old 03-05-2014, 07:19 AM
LsoneGT's Avatar
Mine is square. Zero issues using upr a arms.
Old 03-06-2014, 08:59 AM
usdmholden's Avatar
Ah-ha, quality control. The reason I did not buy a second AJE after having the first AJE.
Old 03-06-2014, 11:54 AM
The Guy in MY 99TA's Avatar
yeah im gunna go with team Z stuff. I been reading too much about AJE that I don't like.
Old 03-07-2014, 03:41 PM
06Sierra2's Avatar
My A arms would not slide in at all. I could get one bushing to fit but not the other side and vice versa. I took a rubber mallet and beat the tabs out a little for the arms to fit. Everything seemed to bend back in place and tightened up the gaps just fine when i tightened the bolts. My manual steering rack didnt fit on one side at all either. I had to take a dremel and slightly modify the hole in the K. Everything tightened up fine but it was annoying and i would probably buy a different K member in the future.
Old 03-07-2014, 05:33 PM
Sleeperls's Avatar
I would have went team z if i had known the new design worked with the f body pan.
I got the k member in the car today with not much hassle.
Quick Reply: New design for aje k member?
