Best way to install Autometer Coolant sensor and keep factory sensor?
I would like to install my Autometer coolant sensor and gauge, however I would like to keep the factory coolant temp sensor connected so I am able to data log ECT.
Anybody know of a adapter so I can install the Autometer coolant sensor, while retaining the factory LS sensor as well?
forgot the part numbers you will need, call autometer. but its the 11mm adapter and their short sending unit so it will fit. you need to take out the allen plug on the passenger rear head, same position that the oem sender is in, just reversed (heads are reversible)
You have a few options
Get a radiator hose adapter. These eBay for pocket change come in various sizes and are threaded for 1/8" npt. I have one for my steam vent lines.
Or make a "tee" up for the outbound heater hose (5/8") from 1/2" npt parts and bush down accordingly. This is how I have my mechanical gauge hooked up.
FYI
I had a mechanical gauge that would not fit that adapter, my mechanical gauge has 5/8"-18UNF male
I could have drilled and tapped the LS port from M12 to M16 and then used ATM-2275, but I just bought a Electrical Autometer Water gauge instead so I wouldn't have to drill and tap.
The risk of getting shavings in the steam tubes scared me.
