Modifying Fbody pan for LS1 swap into Gen 3 nova, need help
Hi guys,
I'm dropping an LS1 into my 73 Nova and need some help. I used the Hooker LS swap brackets and T56 transmission crossmember and cut the heck out of my stock tunnel. So as it sits all bolted up, My Fbody pan is 3" from the rear of the factory crossmember. The steering linkage bolts up, but the car wouldn't be able to turn. I'd like to cut as little as possible out of the Fbody pan, can some one take a pic of the dimension needed from the back of the crossmember to the clearanced spot on the pan?
Here's where I am at:
Thanks guys.
Thanks guys.
I think I have some reference info that may be helpful to you in dimensioning your pan. The new Hooker 302-2 pan that was developed specifically to work with the Hooker engine mounts you have in your car has a sump length of 9.75" and fits perfectly with the stock steering of your car. If you plan to upgrade your steering to the Ridetech TruTurn system, we've just discovered that it requires another 1/4 of clearance at the front of the sump to accommodate that upgrade, so you would need to shorten your sump that extra amount if you plan to go that route.
I would buy the Holley pan and be done with it as cutting and welding a previously used pan is usually very hard to get cleanly welded due to contamination with oil. Just my 2cents worth.
So, it may look like a lot BUT when the steering is turned lock to lock, the center link MOVES FORWARD...I learned this AFTER I cut the pan.
Also, the the center link hits the side of the pan which is why there is that little triangle thing on the side of the pan.
