Flipped forward manifolds and welding cast iron,techniques ?
Which flipped forward and down LS manifolds fit without interference in 70 chevelle?
Cuz my truck manifolds hit frame on pass side and steering on driver side
How and what's the procedure on welding cast to mild? I only have flux mig and stick machines and wanna do it myself. So many have welded mild to cast without pre/post heat but i tried on some scraps and it's "tinging" and cracks.
Suggestions?
Suggestions?
I'm doing the same thing on my car. Flipping the stock truck manifolds forward and up. The passengers side fits fine. But, the drivers side is hitting the steering arm ever so slightly. Not sure what to do about it yet, either see if I can grind a little bit off of the manifold or change the steering shaft. What would you guys recommend?
I dont believe ANY of the factory manifolds fit down and forward without hitting,you may be able to do some very serious modifications to them and they might fit.I have an LS4 on the passenger side down and forward and a 6.0 manifold modified down and forward on the driver side and it fits pretty good but dont have any pics on my computer to show you,I also dont have factory steering anymore as i went to a front mount manual rack and pinion kit. my setup is being built for twins but not sure if i will run it like this as i have almost no room for the down pipe on driver side cause of steering column and master cylinder so i might put them up and forward to create some room.I did have to grind on the LS4 mani a bit to clear everything on passenger side also and its close to motor mount but it does fit.
mines actually a 68 camaro,I figured a chevelle would have alittle more room than i have but maybe not,They actually weld up pretty easy,we just pre heated mine with a rose bud torch and welded it up with a mig and kept some heat on it alittle bit afterwards and no problems at all.i did have to grind off the heat sheild lugs to get it to fit and its close to my motor mount frame stand and frame but maybe im wrong and a chevelle doesnt have more room like i thought.
This is the flipped up truck manifolds on my car. It rubs the bolt on the joint closer to the firewall but I changed the nit and bolt to a smaller one and that fixed it. I also just used a mig welder to weld the pipes and flanges to the cast manifolds. Haven't had any cracking issues in the 2 1/2 years its been together.
cut them weld vband on it , looks alot nicer ,, loses some unwanted weight , easier clearing stuff . [IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
this is a camaro. but as you see, it wouldnt matter what it goes in .. i personally do not like the looks of the manifolds flip unside. down , i did it on my first build .. 70 chevelle . .ive also done log setup on 70 chevelle , i now stick with with them facing foward and down with 2" crossovers,, , like the looks alot more .. easier to get to spark plugs etc .. dont have to move coils underneath or make plug wires longer etc , burning plug wires ... next build im doing is 68 chevelle i just picked up.. im prob getting the shorty swap headers , flipping them forward and down.. lighter and $200 isn that bad still not 100% is they will clear the powersteering box. http://www.ebay.com/itm/1964-77-Chevelle-LS1-LS6-LSX-Stainless-Shorty-Chevrolet-Engine-Swap-Header-Pair-/161235489355?pt=Motors_Car_Truck_Parts_Accessories&hash=item258a62524b&vxp=mtr
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
This is how mine is done but for a twin setup and i have no room for a downpipe on driver side but if your running a single on passenger side you will be good to go.
I was lookin for some shorty headers like these but in mild steel so i could weld them myself,know of any?
i just turn my mig welder way up on heat , and focused more of the weld into the manifold .. reading somewhere they have quite abit of steel in the manifolds ..
Thats weird, usually you cant weld cast iron like that...they must be made from a high grade steel to be able to weld cast with a MIG and not have cracking, especially with a turbo sittin on one end like that. Its good to know though
I used a driver side truck manifold facing down on my passenger side and another driver side truck manifold facing up on the driver side on my 69 Chevelle. . I canted the pipe that I welded to the pass side slightly to clear the frame.
The drivers side is where I put an extreme slash cut section of pipe to face almost straight forwarded.
I preheated the manifolds in front of a jet heater to 450 degrees before I hit them with a torch then welded them with a wire mig. After welding them I put them in front of the jet heater again for about 10 minutes before I let them cool. Then back in front of the heater again. These things weld surprisingly well.
I'd love to post pics but i haven't had any success at it.
Just wanted to add that so far I've retained the factory A/C which has made this build a MF.
