alternator relocation bracket
Old 05-03-2014, 07:46 PM
tom70's Avatar
Default alternator relocation bracket
Putting a lq4 in a 76 camaro drag car using an electric water pump only want to drive alternator. Want to put alternator down low.
Thanks
Old 05-03-2014, 11:52 PM
sfiore's Avatar
have a alt. bracket from a 09 pontiac g8 gt
puts if low on the passenger side
check gm parts direct for diagram for placement
or look at pictures of an L76 engine
s
Old 05-04-2014, 06:49 AM
garys 68's Avatar
Do a search. There are a couple companies that make a low drivers side adjustable bracket for alt only.
Old 05-04-2014, 07:20 AM
Gray86hatch's Avatar
Bmr has a bracket
Tim
Old 05-05-2014, 04:56 PM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
We offer our BMR alternator relocation bracket that should work for you.
Here is a link to it off our website:
http://www.bmrsuspension.com/index.c...&productid=248
Give me a call and we can verify if our alternator relocation bracket will work for you.
__________________
Glenn ***
Sales Tech
813.986.9302
Find a Quality alignment shop near you!
Old 05-06-2014, 02:43 PM
tom70's Avatar
this bracket will allow alternator to clear steering components?
Old 05-06-2014, 02:50 PM
BMR Sales2's Avatar
On a 4th gen F-body it will but I can't guarantee fitment with your setup since I have no clue how you are setting the steering up on the car. If you had the motor installed in the car along with the steering component I could tell you whether it would work with some measurements.
__________________
Glenn ***
Sales Tech
813.986.9302
Old 05-09-2014, 11:02 AM
tom70's Avatar
my block doesn't have a place for #1 hole.
Old 05-09-2014, 12:31 PM
toxic99's Avatar
I was able to get mine to work with 4th gen factory alt brackets in low drivers location. Was tight but it fit. Thats is with 1 inch set back plates too. But, im pretty sure you have front steer so may not work for u. And you can drill and tap your block to fit that bmr bracket and/or factory 4th gen setup.
Quick Reply: alternator relocation bracket
