GM A body LSX swapped with factory air box
Most of the Chevelle and GTO lsx swaps I see are deleting the AC box off the firewall or are factory heat only cars. What about you guys that are keeping the AC box on the firewall?
How are you fitting your LSX engine in the engine bay? 1 inch forward plates? Indenting the box using heat?
Trying to decide what I should do.
I am using the Factory suit case.. I have my engine sitting pretty far rearward also.
The header does come very close to the box. I cut a 3" x 3" lower corner out, flipped it inside out and glassed it back together. By doing this it gave +1/2" more clearance and enough room inside the box for the internals. Pretty much indenting it as you questioned.
BC
BC
I used the Dougs plates and Energy Suspension mount pads. I have plenty of room around the AC box. I did upgrade to a POA eliminator, much larger parallel flow condensor and custom hoses on the pressure side. All in all after I finally got a working compressor everything is working according to plan.
Since the picture was taken I have changed the connector and wiring to the POA eliminator (green wire and connector). This also shows the first attempt pressure hose.
That looks nice and clean. I just have some eBay plates that allow 1 inch back, stock location, or 1 inch forward. I just got some short wide frame mounts from summit. No motor mounts yet. I need to add a 1\4 inch plate under the frame mounts to raise it also I guess. To account for the tie rod zerks.
I guess a lot will depend on the pan you use for fore aft placement. In any event you should still have plenty of room for the AC box. In my opinion the only issue will be getting to the bell housing bolts on that side. If you go the mid position with the adapters you can get them all from the bottom.
I would also add that it will be tight going on changing plugs on the back two plugs on the Right side (#6 and #8) if the Factory Box is utilized. I end up going from the bottom to get to those two plugs.
I also glue a sheet of installation to the box as I stated before, my Headers are very close.
BC
BC
You guys are a great help. Thanks.
Im trying to get all my ducks in a row before I pull my poncho engine out. I'd like to get this as close to right the first time if possible. I'd like it even more if I do not have the tie rods hitting or have to cut my drive shaft! I will eventually run the AC so thats why I was concerned with that. That will be another project after the LSX is in a running. Im not doing any engine mods until that sucker is in and running good. I don't want to present unnecessary problems to start with.
This will be a 5.3/4l60 swap using the F body pan, truck accessories, F body manifolds, truck intake manifold. I have already worked out my 5.3 harness.
Oldgoat69, I have a question about your AC setup. I was mocking up my plate, motor mounts and frame pads to the engine last night on the engine stand. I noticed my motor mount covers up one of the holes in the block that was used for the Truck AC bracket. So my question is, what compressor & bracket are you running and did you notch the frame so you could use a low mounted compressor?
Thanks, John
Thanks, John
For you A body guys that are on facebook check out this page I recently started for A body guys with LSX swaps. Love you have you guys on there.
If this is not allowed here mods please delete this post.
https://www.facebook.com/groups/6463.../?notif_t=like
