6.0 swap into mustang experts please enter
So I'm wanting to build a single turbo street car 6.0 fox or sn95 starting soon.. Can you guys give me some tips? What Auto trans works best 4l60 or 80? What all has to be changed? I want to run A/C and power steering. Anyone know a good place to find a truck wrecked or engine to pick up? What kind of power are these 6.0 motors capable of stock, or with stock bottom end? What should you upgrade on these motors? Any and all recommendations are welcome. Looking for the best budget reliable way to pull this off. Thanks in advance
Note: Youll have a dozen guys come in here and bash my response and say I JUST THREW A 200K MILE LONGBLOCK IN AND IT WAS FINE. That is the cheapest way to go about this and by all means has worked in the past. If you want to avoid having issues down the road, best bet is to freshen up your motor before doing anything else. You can find guys that build fresh 5.3's and 6.0s and give up on their projects. Most sell for $1200-1500 with all new hardware.
Patience and $$$
Street car run an 80, strip car TH400 or a glide
On what exactly?
No you dont, manual rack and windows down!
craigslist, ebay, junkyards in your area, $700-1000 for a complete 6.0 will be a good deal.
Stock bottom end with the right parts 800-1000hp on many setups has been achieved.
Buy a junkyard motor, replace rod bearings, main bearings, file fit new piston rings, ARP rod bolts and headstuds (or equivalent....pro comp: ebay) and all accompanied gaskets. This is for those HIGH mile pickups.
Optional: Boost cam, new lifters, pushrods, valvesprings, trunion bearing upgrade
Patience and $$$
On what exactly?
Hey im all about getting it running then freshing it up later on down the road.. What all has to be changed on the 4l80,to hold that power. And what Has to be changed to the mustang?
Would you run a stand alone CPU?
Have you read a single thread or post on this forum? Nobody is going to hold your hand and give you an instruction manual. Every single thing you have asked has been answered 50 times and half of it is covered in the first 3 pages. What do you mean "what has to be changed on the mustang?" That is the most vague question. The k member the motor mounts the oil pan the exhaust the transmission cross member the driveshaft the gauges the ecu the shifter the fuel pump etc etc.
It's kinda like walking into a restaurant and sitting at our table, interrupting us and asking about the menu.
There are probably 75 threads on this site specifically on Mustang swaps. Just read through a few of them and you'll have 90% of your answers.
He is right though man. I trolled the LT1 section for 3 years before I even started in on my first car. It helped me narrow down my part selection and even find my mechanic to help me work on it(read: do it for me). The subforums are for help yes, but if youre asking questions like these, its obvious you havent even looked at the first two pages before asking your question.
The 4L80e fits with minimal trans tunnel massaging. You'll have to fab a trans mount, I don't think anyone offers one for the 80e, I bought one for a 60e swap and moved the mounts back to accommodate the longer 80e, simple enough.
Power steering is easy, 1 adapter fitting on the GM pump, 1 adapter fitting on the rack and a hose between them, you're done.
Buy a standalone harness from BP Automotive if you are going to use a stock ECU. I bought one and it fits perfectly. The main trunk is just long enough to mount the ECU under the passenger seat.
This thread would be a good one to look at for a beavy of ideas. Probably one of the most comprehensive fox swap threads ive seen on the web.
https://ls1tech.com/forums/conversio...ack-build.html
Sorry to revive a older thread, I've got a 6.0 with 4l80e for free and plan on doing a swap to a sn95. I was going to use the 4.6 k member with 4.6 motor mounts with 1/4" adapter plates from reading that also works. What else would I need to keep AC and PS. And should I fab a cross member for the l80 or just buy the l60e cross member and move it back like the earlier post said. The 6.0 comes with all electronics too. I was going to also use that.
I'm going to make adapter brackets to bolt my Ford A/C compressor and Ford power steering pump to the LS. That way I can keep power brakes and steering.
For the A/C, will I need to keep the stock computer ('99)? I'm using the Holley Dominator EFI to control the engine/trans.
