New Hooker 73-87 GM truck LS swap system preview
#141
Hooker swap stuff was poorly engineered for my Fbody and didn't fit. Hooker acknowledges the mistake. I would go with a less expensive option if I had to do it again. Your call.
#142
The subframe of your 2nd-gen Firebird has a different engine mount bolt pattern layout than a 2nd-gen Camaro and requiring you to drill holes in a different location than a Camaro guy has to makes the Hooker products poorly engineered? I don't get it.
#144
A wouldn't actually consider it a backorder as the first production run has not been completed and delivered by our supplier yet. I had a manufacturing issue with the pre-production sample that was sent to me by our supplier (they welded one of the frame rail mounting feet on backwards), so I've had to work with them to get it corrected. These types of things are typical for new parts, but it has pushed the deliver of the crossmembers back another few weeks from my last posted update.
#153
I understand its out of your control but it doesn't make a whole lot sense for Hooker (as a business) to offer part numbers and pricing when parts are simply not availble for up to several weeks. Just disappointing for someone who is waiting on them to finish a build and enjoy it. Why make parts availble when they are not availble.
#154
#155
#156
Sunday 4/19 update- the first production run of the 3" exhaust systems were completed last week (both the dual side exit and the dual rear exit versions) and boxed up, which means they'll show up in the system as being available within the first couple of days this coming week.
#157
#159
