89 Fox 6.0 w/ 88mm Turbo
I have been a longtime lurker on this board, I figured its time to start posting. I've learned a lot of things from this site. I have always had a thing for Fox body mustangs, after messing around with all the possible toys a guy could have, I finally started on mine. I am going the turbo route with this car, going to be starting on that part of the build in the coming weeks. Parts are coming in... Not really shooting for a specific HP range, looking more for sub 9.90 track times, and maybe cause some hurt feeling when cruising around.
I'll try to keep this thread updated as much as I can, once I start its going to go fast. Hoping to have it done in time for TX2K, but we will see how things go.
As it sits right now:
89 Mustang
6.0 LQ4
TSP 233/239 cam
TSP Pushrods
PRC Springs
LS2 timing chain
Jake's Performance Stage 1 TH350
Jake's 4000 Stall
3.73 gears
Car has been low 12s on this setup.
COUPLE OF IDLE VIDS
Idle through dumped, exhaust
http://i1073.photobucket.com/albums/...pssniyphgc.mp4
Exhaust cut outs open
http://i1073.photobucket.com/albums/...pses08dulc.mp4
89 Mustang
6.0 LQ4
TSP 233/239 cam
TSP Pushrods
PRC Springs
LS2 timing chain
Jake's 4000 Stall
3.73 gears
COUPLE OF IDLE VIDS
Haha we will see about that. As long as it gets me to my target time
GT45 88mm from VS Racing. Going budget route on the first go around. Have another LQ4 I'm gonna put all the nice stuff on and go with a BW turbo for that.
89 Mustang
6.0 LQ4
TSP 233/239 cam
TSP Pushrods
PRC Springs
LS2 timing chain
Jake's 4000 Stall
3.73 gears
89 Mustang
6.0 LQ4
TSP 233/239 cam
TSP Pushrods
PRC Springs
LS2 timing chain
Jake's 4000 Stall
3.73 gears
grab some 60lb or 80lb Deka injectors and head studs from Alpermotorsports off ebay...
I'm also unsure that th-350 will survive a few passes at 9.90...
I'll be following the build, as my buddy is just now tearing his 5.3 down to put into his fox as well with an S480... should be on the road by late spring...
Since you're listing parts, you'll need injectors and almost definitely a set of head studs...
I have ARP head studs. Will order Injectors in the next few weeks, forgot to mention going to run E85 as it is cheap around here. So probably 160s at the least, and a Fuel Pump (MagnaFuel 750 or Holley Dominator).
The TH350 will be on borrowed time, I have both a TH400 and a 4L80E sitting for when that time comes. Just don't know which one to use, OD would be nice to have.
How do you like the 4L80E in your Nova? Looks like you have a pretty sweet build going on yourself.
The angle of the pics make them look like they stick out more than they do.
