1000+whp Mustang Street Car
Well, here we go. I haven't made a build thread on the car yet so I figured that I might as well. I'm James, I'm a 21 year old college student and this is my "budget" build. I'd like to thank Jon from FIC for being a huge help with the car. This is my 2000 Mustang v6 that i bought with a blown engine for $1300. It was probably one of the cleanest, low milage new edge mustangs that i have ever seen. I almost feel bad for doing what i did to it. It now terminator cobra replica. The original goal for the car didn't get followed at all. It was supposed to be a full interior car, no roll cage, no turbos, no automatic. I had a nitrous 347 sbf and a g force t5 that i was going to use for a fun daily/weekend car. Turns out things escalated quickly and here we are. Everything on this list is stuff that i already have. This build has been a year so far, progress is slow for the most parts. Opinions are more then welcome on the build, constructive criticism is always more then welcome. The car will run on pump e85 and e98 if I'm feeling froggy. It should be a fun car that i can drive to work and back while being competitive at the track.
Chassis/Suspension:
Tucked 10 point cage NHRA Cert to 8.50s
Flaming River Manual Steering Rack and shaft
Racecraft tubular Steering column
Grant steering wheel
Wilwood floor mount brake pedal w/ in car master cylinder
Locar throttle pedal
2x Kirkey Seats
Skinny Kid 99-04 Parachute kit for drag wing
Stroud Parachute
Team Z Metal Matrix (LSX) tubular k member
Team Z adjustable tubular front A arms
Team Z solid engine mounts
Team Z Through the floor subframe connectors
Team Z adjustable lower control arms
Team Z adjustable upper control arms
Team Z X-treme Duty Anti-Roll Bar
Team Z Coilover Mount
Team Z Caster Camber Plates
Team Z bump steer Kit
Strange 10 way struts in front
Strange Front Coilover Kit
Strange Engineering Hypercoil 12-125 front coilover springs
Strange Single Adjustable Rear Coilovers
Team Z rear coilover mount
QA1 12-150 rear coilover springs
UPR Reinforced upper and lower torque boxes
Summit racing line lock kit
Summit Racing battery relocation kit
OEM brakes
Sheetmetal full width drag wing
Transmission:
Bergeron Racing Transmissions Th400 rated for 1200whp
Reverse manual valve body
Hipster transbrake
Hurst billet pistol grip quarterstick shifter
FTI 3800 stall turbo converter
TCI SFI LSX to TH400 Flexplate
Allstar Performance SFI Rated Transmission Blanket
TCI SFI Rated Flexplate Shield
ATI Transmission Catch Can
ARP Flexplate bolts
Rear End:
Strange engineering 8.8 (cut down to foxbody width)
Welded Axle Tubes (3 passes per side)
Strange Engineering 3:27 gears
Strange Engineering 35 Spline Full Spool
Strange Engineering 35 spline Axles
Strange Engineering spool bearings
Strange Engineering C Clip eliminators
Strange Engineering 1350 Chromoly Pinion Yoke
Custom Aluminum Driveshaft
ARP 1/2" Extended Wheel Studs
Trickflow Differential Girdle
Engine:
2006 LQ4 Destroker
Gen III 4.8l Crankshaft
Eagle 6.3" H Beam Rods
ARP L19 Rod Bolts
Stock 317 head Castings
Alper 1/2 Headstuds
ProComp Mainstuds
LS9 Headgaskets
CBR Alternator Relocation Accessory Drive
02 Camaro alternator
Aluminum 3 core jeep Cherokee radiator
Fuel System:
FIC 2000cc Injectors
Summit Racing 15gal fuel cell
Electronics:
MS3-Pro Standalone EMS
Custom wire harness
Corvette ZR1 3 Bar Map sensor
AEM IAT
Mac ECBS
Turbo kit:
Twin GT45s T4 1.05a/r
Ebay turbo headers
Custom hot piping with 4" fender exit exhausts
2x Tial 44mm MVR wastegates
2x Tial 50mm Q bov
CXRacing 5" a2a intercooler
Nitrous:
Zex universal single nozzle kit (for spool)
I Hope that i didn't forget anything.
Chassis/Suspension:
2x Kirkey Seats
Stroud Parachute
OEM brakes
Transmission:
Hipster transbrake
ARP Flexplate bolts
Rear End:
Engine:
2006 LQ4 Destroker
ARP L19 Rod Bolts
Alper 1/2 Headstuds
ProComp Mainstuds
LS9 Headgaskets
Fuel System:
Electronics:
Custom wire harness
AEM IAT
Mac ECBS
Turbo kit:
Ebay turbo headers
2x Tial 50mm Q bov
Nitrous:
Yea? should be a regulation. were the safest cars on the road lol
doubt it, this things a turd too lol. I've owned it for a year and this is where its at.
Neither can I haha, yea its been a long time coming to buy everything. i usually wait until team z is running a sale or ill shop around for a while and find the absolute lowest price on whatever it is that I'm looking for.
These are some random pics throughout the build. They're not in order (will fix). It's been a long progression but she's defininately made a complete 180.
I know this is an old thread, but I just wanna know if I just want to drop an LS engine inside a V6 mustang do I need to do any cutting for the engine? Don’t wanna do anything special
What year Mustang?? You need to cough up MUCH more info.
