LM7/L33 S13 Swap
Old 05-24-2015, 07:57 PM
LsS13's Avatar
Default LM7/L33 S13 Swap
hey guys my question is probably not very smart but I need to know i want to grab preferably the all aluminum l33 vortec aand swap to my s13 but just to make sure i need the complete engine harness (obdII included) and the factory pcm? Also when i get those I need to get the pcm reflashed? and lastly is the trans harness part of the engine harness? im new to swapping different makes i usually stay in the realms of the manufacturer lol any help would be apperciated!!!
Old 05-25-2015, 06:50 AM
casias's Avatar
For your first time, I would recommend getting a complete drop-out with engine, trans, wiring harness, ECU, and all accessories. Find a salvage yard that does this regularly, so they know what you need. Little things like exhaust flange and transmission yoke sometime get forgotten, and are hard to find later on.
Next...send your harness to one of the vendors on here, like BP Automotive, who will rewire your harness.
Last.....Plan on finding a local tuner who has experience with LS swaps. They do have their quirks, and sometimes need more time than a "canned" tune.
Good luck.
Old 05-25-2015, 06:52 AM
LsS13's Avatar
Awesome I do apperciate the info! about how much do it cost to rewire a harness from bp auto?
Old 05-25-2015, 06:55 AM
casias's Avatar
Maybe $300-400, depending on what you need done.
Old 05-25-2015, 06:57 AM
LsS13's Avatar
okay cause i got the lm7 and a t56 from an lt1 that im gonna convert over to use on an ls1 but the harness has the trans wire on it as well am i correct?
Old 05-25-2015, 07:04 AM
casias's Avatar
Not sure on that. I don't mess with wiring at all. It's too time consuming, in my opinion, to remember all of the variations.
Old 05-25-2015, 07:05 AM
LsS13's Avatar
Thats no biggie ill be going to pull the motor this weekend from my local junkyard so ill just oberve it then also does bp auto do pcm reflashes?
Old 05-25-2015, 07:13 AM
casias's Avatar
Probably. I have never used them, but I know they are one of many mentioned on here. Most will remove VATS, if you have it. But you still need a local tuner to really get it right.
Quick Reply: LM7/L33 S13 Swap
