Just another ls foxbody.
Old 06-03-2015, 12:44 PM
penningta's Avatar
Default Just another ls foxbody.
Im building a 1989 fox hatch. Had a sbc in it but am almost done building a lq4 for it.
lq4 .030 over
stock crank
compstar rods 6.125
Je dome pistons make it 13.2 to 1 compression
PRC Ls3 ported heads
Cammotion hydraulic roller cam. cant remember specs right now
Morel high rpm rollers
super vic intake
jim evans 750 carb 112 sunoco fuel
dynatech 1 7/8 headers
Glide
PTC 8" convertor around 5000 stall
28 10.50 tire 2750 lb race ready
Hoping for 625 hp and 9s
Old 06-04-2015, 09:17 AM
bs636's Avatar
nice build!
Old 06-05-2015, 08:13 PM
Silver408coupe's Avatar
Nice building! How do you like the Afco K member?
Old 06-08-2015, 01:08 PM
penningta's Avatar
It works. Fit pretty good. Have to run coil overs with it though. Other then that its great
Old 06-08-2015, 01:19 PM
M.BOZZ's Avatar
I still love ready fox builds, looking good
Old 06-10-2015, 08:47 PM
Zmg00camaross's Avatar
Get it running yet?
Old 06-12-2015, 11:52 AM
booboo37's Avatar
what oil pan ?
Old 06-13-2015, 10:37 AM
penningta's Avatar
Originally Posted by booboo37
what oil pan ?
2009 silverado 6.0 pan. Hangs down about 1 1/2" below k member. As long as the wheels stay on the gound Ill be fine>
Old 06-13-2015, 12:48 PM
I will come loosen your front shocks
Old 06-14-2015, 08:50 PM
Bowtiedford's Avatar
looks good
Old 06-18-2015, 12:09 PM
penningta's Avatar
They are as loose as they will go sucka!!!!!!!!!!!!!
Old 07-17-2015, 10:11 PM
penningta's Avatar
here is the dyno results!!
Old 07-18-2015, 07:18 AM
SSSTANG#1's Avatar
Cool! Flywheel or rear wheel? What kind of fuel are you using? What are the cam specs?
edit...found you on YB.
Old 07-18-2015, 08:09 AM
Gray86hatch's Avatar
Looks good.
I think the converter is at least 1000 to tight. I would try to get it 6400 and shift at 7500 thru the traps over that.
What weight. If 3000 it should go 9's but the converter will be holding it back.
Tim
Old 07-18-2015, 08:38 AM
nice numbers
Old 07-18-2015, 11:49 AM
Engine dyno numbers.
Old 07-18-2015, 07:20 PM
penningta's Avatar
Originally Posted by Gray86hatch
Looks good.
Tim
Converter is at the shop as we speak. Im sure its gonna end up higher then what I thought, After dyno Im thinking the same as you.
Car is only 2750 with me in it. Maybe 2800 with new setup. Should make for an easy 9s
Old 07-18-2015, 07:25 PM
That will work. Converter is a huge deal on a na car.
Tim
Quick Reply: Just another ls foxbody.
