minimal GTO harness w/ e40 pcm
Old 07-06-2015, 12:34 PM
Ls2_vert's Avatar
Default minimal GTO harness w/ e40 pcm
I have a ls2 from a gto with an e40 pcm and oem harness. i will be using a switch panel for igniton, fans, and fuel. dont need gauges or A/C. just want minimum to make car run. im wanting to remove whats not needed from the harness any help or writeups would be great.
Old 07-06-2015, 12:42 PM
Suncc49's Avatar
Lt1swap.com has great write ups and full pinouts... there are also some videos on youtube on how to do it
search how to 4 wire your swap harness
Old 07-06-2015, 12:56 PM
Ls2_vert's Avatar
My main problem is I can't find harness info to power the coils and pcm for a gto harness. I have 4 wires at then of my harness that was powered through the headlight harness on the gto but I don't k ow what wire is what.
Old 07-06-2015, 04:03 PM
Suncc49's Avatar
The diagrams on lt1swap will show you. You will have to make your own fuse box for standalone wiring
Old 07-06-2015, 05:13 PM
76larkman's Avatar
basically gm used pink and some orange for hot wires. orange out of pcm plug is constant 12v battery power for pcm. then pinks on with key and during cranking. mass air flo, tranny connector, 2 oxy sensors, 8 injectors. 2 computor on off key, i tied the 4 injectors on each side together into 1 wire the run the 2 wires to 10amp fuse. same with oxy sensors 10amp, pcm 10amp, mass air flo & tranny plug to a 10amp fuse. You can do a universal fuse panel or single fuse holders dont matter but mark everything well. fuel pump needs a relay. pin 86 a ground. the fuel pump out wire from pcm pin 85, pin30 goes to positive on battery, pin 87 goes out to pump. most relays are marked with those numbers. Hope this helps
Old 07-06-2015, 09:36 PM
TipsyMcStagger's Avatar
The coils and injectors in the GTO/E40 harness are powered through the C101 connector, which is a six pin connector with five pins populated.
C101 Wires Should Be As Follows:
Pink/Lt Blue = Reverse Lockout
Black/Red = Ground
Lt Green = Left Side Coil Injector 12v
Dk Green = A/C Clutch
Red = Right Side Coil Injector 12v
Tipsy
Old 07-07-2015, 10:22 AM
brawls43's Avatar
Brendan from lt1swap does a nice walk through for pinning out your power wires as well. Check it out on his facebook page. Its not your exact harness, but for me this helped it make more sense when I was doing my L76 harness.
https://www.facebook.com/media/set/?...5211824&type=3
Old 07-07-2015, 11:47 AM
LT1Swap is the default suggestion for LSx wiring information and rightfully so. But that site does not support the E40 PCM.
Additionally, the GTO E40 harness is somewhat of a different animal in that it is a Holden (Australia) product and the coloring convention is different from most other GM produced LSx harnesses.
That being said, it's actually a pretty easy harness to modify. All of the power comes into the harness through the C101 connector and the C206 connector.
I've already indicated the C101 pinout above.
The C206 pins are as below:
*Note: This is from a 2006 GTO Manual Trans harness. There are additional C206 wires in the Automatic Harness.
  • Pin 1 - Brown looped to Pin 4 (CAN Bus)
  • Pin 2 – Black - goes to C3 Pin 49 (Fuel Tank Pressure Sensor)
  • Pin 4 - Brown looped to Pin 1 (CAN Bus)
  • Pin 5 - Brown w/Black looped to Pin 12 (CAN Bus)
  • Pin 7 - Brown w/Blue - reverse light sensor
  • Pin 10 – Dk Green - into the horn connector and Black/Red (Ground) out of the horn connector.
  • Pin 12 - Brown w/Black looped to Pin 5 (CAN Bus)
  • Pin 13 – Pink - merges with other pinks (O2 sensor power)
  • Pin 15 - Lt Green w/ Black - goes to C3 51 (A/C Comp. Control Relay ECU output)
  • Pin 21 – Yellow - reverse lockout
  • Pin 22 - Lt Green - reverse light sensor
C206 Pins 1,4, 5 & 12 (CAN Bus) can be eliminated if you're not utilizing a GTO BCM (Body Control Module).
C206 Pin 2 can be eliminated if you're not running EVAP.
C206 Pin 10 can be eliminated.
The remaining are O2 power, A/C, reverse lockout & reverse lights and should be self explanatory.
Tipsy
Old 07-07-2015, 12:13 PM
Here's the pinout for the blue 56 pin C1 (sometimes called J1) connector. This pinout list and the pinouts of the C101 and C206 listed above are everything you'll need to make your LS2 GTO harness stand-alone and functional.
Old 07-07-2015, 07:09 PM
Ls2_vert's Avatar
so these are the wires that come out of the harness around the maf. they usually go to a plug that goes to chassis harness for power im thinking. but idk what they are. and as far as c1/j1 blue connector i have removed everything i dont need. only ones im not sure about are
10 20ga BROWN Engine Relay Coil Control
13 20ga YELLOW Starter Relay Coil Control
14 18ga PINK Ignition Voltage
18 20ga YELLOW Accessory Voltage
19 18ga ORANGE Ignition Voltage
20 18ga ORANGE/BLACK Battery Positive Voltage
32 20ga DARK BLUE/RED Stop Lamp Switch Signal
45 20ga DARK GREEN/WHITE Fuel Pump Relay Control
52 20ga PURPLE Crank Voltage
do i need any of that running a switch panel to a custom chassis harness? i already have dbw and can port wired up
Attached Thumbnails minimal GTO harness w/ e40 pcm-11667138_10203323824095181_1061093504_n.jpg
Old 07-07-2015, 10:36 PM
It's hard to tell without a connector or other context but based on your description, it looks like that could be (what was) the C101 connector, though it should have five wires.
Look at the info in Post #6 and see if you can verify continuity.
Tipsy
Old 07-07-2015, 10:55 PM
Ls2_vert's Avatar
ill check that when i can. thanks for the help
Old 07-08-2015, 12:47 PM
brawls43's Avatar
That being said, it's actually a pretty easy harness to modify. All of the power comes into the harness through the C101 connector and the C206 connector....
Tipsy
Yeah I was more referencing his process of walking through a harness. He didn't have diagrams for my harness either, though its similar to an LS3. For the L76 I had to find diagrams on the G8 forums, similar to the info you provided. But I think reading through the his process, which he steps through on his facebook page, would potentially help the OP understand his harness better. It did for me.
Back to his question post #10 around these wires:
I think you want all the voltage wires. The relay control wires is dependent on how you're wiring up your system. Are you still going to use relays for the starter, fuel pump, and engine main power? Even with a switch panel, I'd think you'd want to run relays, in which case, the relay control wires should be useful. These are the signal wires to the relay, to power the relay, which then powers the respective circuits. Back to Lt1swap, I found his section about wiring up a fuse block and relays quite helpful. I'd never wired my own fuse block. Its not a direct step by step for your engine (or mine) but the concept should be applicable. http://www.lt1swap.com/fuseblock_obd2port.html
Old 07-08-2015, 01:12 PM
Ls2_vert's Avatar
All fans and fuel will be through arc switch panel that has wiring and relays. So I don't need any of that. Basically just néed to power harness and pcm.
Quick Reply: minimal GTO harness w/ e40 pcm
