Finally running and driving 71 camaro lq4 swap
Old 09-10-2015, 06:43 PM
Eckel974's Avatar
Default Finally running and driving 71 camaro lq4 swap
Well finally able to drive my car with new "used " 700$ junk yard 6.0. Swap went pretty well. I was surprised it went as well as it did. Bought 2000 6.0 out of a truck and installed hot cam, valve springs, ls2 intake, injectors, everything else stock. Made 273 hp at 4800 rpm on the dyno. We were not able to make a full pull because of a pretty bad vibration. I haven't had time to check drive shaft or pinion angel. Tuner thinks it should make 300 ish with full pull.I know they make better combos then what I have but ls2 intake, rails and injectors were cheap and they were brand new take offs. I don't have enough clearance for truck stuff. My main goal was to get it running I can always upgrade later. This is my first thread hope pics show.
Attached Thumbnails Finally running and driving 71 camaro lq4 swap-image.jpg
Old 09-10-2015, 06:49 PM
Eckel974's Avatar
Trying to get pics uploaded
Old 09-10-2015, 06:55 PM
Eckel974's Avatar
Before cleaning.
Old 09-10-2015, 06:57 PM
Eckel974's Avatar
Old 09-10-2015, 06:59 PM
Eckel974's Avatar
Old 09-10-2015, 07:00 PM
Eckel974's Avatar
Wiring sucks!!!!!
Old 09-10-2015, 07:08 PM
Eckel974's Avatar
Pic of car
Old 09-10-2015, 08:30 PM
Alwhite00's Avatar
LS1Tech 20 Year Member
Looks great. I have a similar setup. 6.0, LS2 intake, LS6 can, ported heads, short headers. Hoping for 400 HP (crank) and 20mpg.
Old 09-11-2015, 08:44 AM
Eckel974's Avatar
You should be at 400 hp. As for mpg depends on trans and gear. What are you running? Mines 3.42 gear with turbo 350 trans. However I found 4l80 for 350$ I think I'm going to buy.
Old 09-11-2015, 09:46 AM
M6 Swap's Avatar
turbo 350 def gonna limit your MPG's. 4L80E MUNCHO BETTER
Old 09-11-2015, 09:59 AM
Alwhite00's Avatar
3:36 gear & 4l60
Old 09-11-2015, 02:05 PM
Eckel974's Avatar
I think you should definitely be close to 20 miles per gallon with overdrive and that gear. I talk to a builder who says they get almost 30 with a six speed
Old 09-11-2015, 02:07 PM
Eckel974's Avatar
Does anyone know when swapping to a 4L80 from the TH 350 how to do the drive shaft. I don't think my stock drive shaft will fit at least I know it's too long but what about you joint set up? Also I think the 4l80 has a 30 splined drive shaft instead of the 28 spline. I guess you I would probably have to find a drive shaft out of the truck and have it modified?
Quick Reply: Finally running and driving 71 camaro lq4 swap
