'78 Datsun 280Z LS2/T56 Swap
Old 06-29-2016, 09:50 AM
Stock Car Mafia's Avatar
Default '78 Datsun 280Z LS2/T56 Swap
Hey guys,
I am a little late to the game but have been staying current on the HybridZ site.
http://forums.hybridz.org/topic/1238...80z-ls2-build/
Last June I picked the car up from Seattle, Washington and really wanted to build a LS swapped car. I spent most of the summer driving the car and doing little things here and there while doing some research.
I went ahead and started ripping in to the car November 18th. Boy oh boy has this car been a lot of work but I wouldn't trade it for anything...
Here are some before and after pictures:
Here's a list of what has been completed up to this point:
1978 280Z - 2,560 lb. after swap
- LS2/T56 pullout from an 05 GTO w/ stock harness
- Hawks Third Gen weld in motor and transmission mounts
- C6 LS3 Oil Pan
- Hawks Third Gen Longtube Headers
- Monster Stage 3 clutch w/ 18 lb. flywheel
- 3" Aluminum driveshaft with billet slip yoke - 9 lb.
- Z31T CLSD R200
- Chequered Flag shortened half axles
- Chequered Flag companion flanges
- Tilton 7/8" Clutch MC
- Wilwood 1" Brake MC
- S12W Toyota vented brake upgrade
- 14 gal. Jeg's fuel cell
- Bosch 044 fuel pump
- -8AN fuel lines
- Ground Control weld in coilover kit
- Tokiko Illumina shocks
- 225/250 springs
- Energy Suspension polyurethane bushing kit
- All suspension was sandblasted and primed by brother and painted by me.
- Rota RB-R 17" x 9.5" on all 4 corners
Here are some of the items I plan on doing in the future:
- VRX5 camshaft
- 0.660" Dual Valve Springs with Titanium retainers
- 7.400" Hardened Push Rods
- Trunion bushing upgrade for the rocker arms
- Port and polish LS2 throttle body
- Port and polish LS2 intake
This I hope to have done by July 11th for a scheduled dyno session.
For the picture oriented people, here is my photobucket link:
http://s176.photobucket.com/user/Sto...?sort=3&page=1
Maybe down the road I will figure out FI and painting/restoring the car however since I got it running less than a month ago all I've been doing is driving!
Old 06-29-2016, 03:58 PM
Annunaki's Avatar
Looks good, I'm working currently on mine.
Old 06-29-2016, 04:03 PM
MemphisRaines's Avatar
Looks great I bet that really fly's with that power to weight ratio
Old 06-30-2016, 08:22 AM
Thank man. Are you going to do a build thread on any of the forums? I love following others' builds for entertainment!
Old 06-30-2016, 08:27 AM
Thank bud. She does buck pretty good! It feels just as fast as some heavier supercharged cars I've driven. I am already craving more power but want to focus on handling as I want this to be a wicked corner carver/road car.
Old 06-30-2016, 09:48 AM
Nismo Kid's Avatar
Welcome to tech. I like the attention to detail throughout the entire build. There can never be too many LSX swapped S30's. If you hadn't purchased a Trunnion kit yet I'd look into the Straub Technologies Trunnion Kit. It's a rock solid kit. I found the summit racing tool made the install a cake job. (Summit part #SME-906011) The tool works with all the Trunnion kits. Look forward to the rest of your build.
Old 06-30-2016, 03:52 PM
Thanks Nismo. I tried to think every step out prior to doing any work. It is far from perfect but I am happy with it currently. Of course there will always be things I want to change. I think there will never be enough swapped cars like this. They are so few and far in between you're lucky to come across another one.
I did pick up a trunion bushing kit from Vengeance. It has the brass bushing so hopefully there is less wear than the needle bearing kits. Time will tell. as far as the install, I bought a hydraulic press when I rebuild the uprights with new bearings and seals and then the wheel studs too. I picked up a couple big thick washers that will act as my spacers to drop the trunions in. I think I should be safe using this and some sockets to get the old ones out.
Overall I should be cracking in to the cam swap tonight or this weekend. I'm hoping to not have any issues.
Old 06-30-2016, 05:11 PM
Annunaki's Avatar
At the moment NO, I'm in HybridZ forum too, although I'm not to active there. I will be putting an LQ4 on mine. At the moment buying parts here and there. I will be using Z32 trans. I'm focusing on my suspension at the moment.
Quick Reply: '78 Datsun 280Z LS2/T56 Swap
