1950 F-1 5.3/60e swap complete
Old 09-03-2016, 11:47 PM
lilpanther's Avatar
Default 1950 F-1 5.3/60e swap complete
Hey everyone. I figured after lurking on here for a long time I would finally post up and make a thread on the truck me and my grandfather built. The truck is a 1950 Ford F-1 and when we got it it had the front suspension from a 77' Lincoln Continental along with the 460 and c6 from the lincoln. After 7 years of slowly redoing the whole truck when we had time we got it done and couldn't get the 460 to run cool and no matter what wheels and backspacing we tried we couldn't get the front tires not to stick out of the front fenders and rub on every little bump. So 2 years ago we started collecting parts and managed to find another stock chassis to put it on. So we took the stock chassis and put a Speedway Mustang II kit on it and dropped in a completely stock 5.3 and 60e from a 2002 Tahoe using c5 motor mounts and c5 manifolds I v-banded and ended up using an explorer 8.8 out back. It's been on the road for about 4 months now with the new set-up and is a blast to drive. I guess that's about it, I'll let the pictures do the rest of the talking.
The day we got the truck.
1950 F-1 5.3/60e swap complete-y4vjcob.jpg1950 F-1 5.3/60e swap complete-sddakib.jpg1950 F-1 5.3/60e swap complete-dwne9zz.jpg1950 F-1 5.3/60e swap complete-19s9sxn.jpg1950 F-1 5.3/60e swap complete-weuoukf.jpg1950 F-1 5.3/60e swap complete-ueiccm8.jpg
Patching holes and fixing the old frame.
1950 F-1 5.3/60e swap complete-qkj9zsm.jpg1950 F-1 5.3/60e swap complete-fophxeb.jpg1950 F-1 5.3/60e swap complete-qdj1ntg.jpg1950 F-1 5.3/60e swap complete-im4hoix.jpg1950 F-1 5.3/60e swap complete-ncawndh.jpg1950 F-1 5.3/60e swap complete-c1c23nk.jpg1950 F-1 5.3/60e swap complete-s42ubco.jpg1950 F-1 5.3/60e swap complete-uz71oqu.jpg1950 F-1 5.3/60e swap complete-yfxjzgz.jpg1950 F-1 5.3/60e swap complete-gg4kuk3.jpg1950 F-1 5.3/60e swap complete-nhmafmy.jpg
How it sat with the old set-up.
1950 F-1 5.3/60e swap complete-b6hghfv.jpg1950 F-1 5.3/60e swap complete-sewp65p.jpg1950 F-1 5.3/60e swap complete-geq2ss5.jpg1950 F-1 5.3/60e swap complete-sgnc7me.jpg
Getting the new frame ready.
1950 F-1 5.3/60e swap complete-qdirsef.jpg
1950 F-1 5.3/60e swap complete-tmuobdb.jpg
1950 F-1 5.3/60e swap complete-g1y0g4m.jpg
1950 F-1 5.3/60e swap complete-ppmal6t.jpg
Ready to come off the old frame.
1950 F-1 5.3/60e swap complete-f5ya5x8.jpg
Sitting on the new frame.
1950 F-1 5.3/60e swap complete-lmaqxhy.jpg
Tabs off the back of the crossmember for the c5 mounts.
1950 F-1 5.3/60e swap complete-rssp1ef.jpg
The 5.3 waiting to drop in.
1950 F-1 5.3/60e swap complete-sopeup8.jpg
Engine in and re-working the stock harness.
1950 F-1 5.3/60e swap complete-txy5gzw.jpg
1950 F-1 5.3/60e swap complete-aithlkf.jpg
1950 F-1 5.3/60e swap complete-thtqrsg.jpg
1950 F-1 5.3/60e swap complete-71vdkau.jpg
Body coming back together.
1950 F-1 5.3/60e swap complete-wopqzho.jpg
1950 F-1 5.3/60e swap complete-131ctr4.jpg
1950 F-1 5.3/60e swap complete-p4gpvgg.jpg
1950 F-1 5.3/60e swap complete-bera8dc.jpg
Engine tucked away under the hood.
1950 F-1 5.3/60e swap complete-v8lcx28.jpg
How it sits today.
1950 F-1 5.3/60e swap complete-epdizal.jpg
Old 09-04-2016, 03:57 PM
Jimbo1367's Avatar
This looks really nice. Do you recall what air filter p/n? Dimensions?
Old 09-04-2016, 07:14 PM
lilpanther's Avatar
Thank's. It's just a$14 ebay filter, It's 6" diameter and 6.75" long.
Old 09-04-2016, 09:28 PM
DavidBoren's Avatar
Well that is a slick little truck. Good job. There is an elegance in simplicity, and your truck is a perfect example of it.
Old 09-04-2016, 10:26 PM
67Skylark's Avatar
Cool Truck, Congratulation
Old 09-05-2016, 07:41 PM
lilpanther's Avatar
Thank's. We were trying to keep it as simple as we could. I still have the original stainless that goes on the hood and grill to put on once I get the clips for it.
Thank you.
Here's a little idle video of it. My phone mic likes picking up the fuel pump more than anything so it's hard to get a good video of it.
Old 09-07-2016, 07:56 PM
Cheese Weasel's Avatar
Neat build - and it's very cool that you got to do it with your grandfather! You might get a bit of grief from the Ford purists, but don't let their "heartburn" distract you from getting enjoyment out of it.
One thing that I have to mention though - unless you have some sort of "cowl-induction" that I didn't notice (that's bringing cooler air in), you're really going to want to change your air-intake location. Pulling it from the top-rear of the engine compartment is just going to feed hot air into the engine. At the very least, that's going to make the ECM pull timing, & will also give you reduced air density/less power. If you can find a way to route it so that it can pull outside air into the engine, it'll run better.
Good luck, I hope you guys get to make a lot of cool memories with your truck!
Old 10-19-2016, 10:15 PM
lilpanther's Avatar
Thank's Cheese Weasel. The IAT's with the filter with it where it is actually aren't that bad going off the ultragauge I'm running, and there's no easy way to move the intake with the clutch fan.
No big updates lately but I got all the trim on and changed out the headlights to a set with clear turn signals. And another note, I am working on getting everything on the truck sorted to take it on the 2017 Hot Rod Power Tour.
Quick Reply: 1950 F-1 5.3/60e swap complete
