Speedometer conversion
I'm doing a 1959 Vette with a LS1 4L60e conversion. I plan to use either a FAST or BS3 ecu. I was wondering what you guys are doing about speedometers? Is there a way or a business that converts them to electronic, or some sort of adapter?
Thanks for any help you can give me. Dave.
Thats a tough one to call. I always recommend dakota digtal units that allow you to recalibrate the signals to match your factory gauge. Since the Vette is cable operated you will have a hard time trying to find it to work. You will more than likely need to buy a digital set of gauges. Maybe someone who has the same problem will chime in.
sawzall wielding director
There are a couple of different ways around this. Some people will change the gauge to an electric one, but this does not sound acceptable to you. Another way that is probably more what you are looking for, is to use a convertor box. Theres a box called the abbott(sp?) cable-X that has an electric motor to convert the signal from the VSS to spin a mechanical speedo. The other way is to put the guts from an electric speedo behind the stock mechanical face.
Thanks for the help!
I used http://redlinegaugeworks.com/ for a VDO conversion for my 1957.
Here are the links to the pictures.
http://home.comcast.net/~pj.rodgers/...eedo_front.jpg
http://home.comcast.net/~pj.rodgers/...peedo_back.jpg
Conversion master
I e-mailed them for the cost of doing my Vette gauges, have'nt heard back from them. Talked to Dakota Digital today and they make gauges that replace the ones in my Vette dash exactly. About 1000$ through Summit. Got a local guy who may be able to do better than that though. Kind of leaning toward this option since I could sell off my stock Vette gauges and offset some of the cost.
Thanks again, you guys have been a ton of help. Dave
Originally Posted by joelvette
i bought the modified tailshaft for the 4l60e that has both mechanical and vss outputs for about 400. i didn't like what i heard about the cable-x having slow and jerky output to your speedo especially at low speed
Somewhere less than $400. Redline Gaugeworks redid the lens and the faceplate including the center section. Should have left the bowtie off the Check Engine Light.
If you have them do it, check the speedo lens, got mine and it took me awhile to realize the 100, 110, and 120 were backwards for the Chevy, Fords flipped those numbers around. Told them and got a new one right away.
Used the programmed 4000 pulse per mile to get it to read right. First time I drove the car, speedo was have speed; used HPTuners to adjust the speedo count and had the speedo reading correctly but the computer saw the car doing 94 mph and the speedo showing 24 mph. Ooops,
Put the HPTuners to put the fudge factor back and reset the speedo pulse count.
4l60e, abbott, bs3, cable, conversion, converter, electronic, mechanical, problem, signal, speedo, speedometer, stock, vdo, vss, x30
