Gto Ls1 Oil Pan Gasket Part Number?
Old 10-08-2007, 05:12 PM
GTOpowered240sx's Avatar
Default Gto Ls1 Oil Pan Gasket Part Number?
Anyone know the oil pan gasket part number for the GTO LS1? Or where to get one? I have been searching here the past hour with no luck.
Thanks!
Old 10-08-2007, 06:51 PM
babydeuce's Avatar
Should be the same gasket as any LSX series engine. I put a GTO pan on my 5.3 this weekend and reused the truck pan gasket.
Jack
Old 10-08-2007, 08:35 PM
I cant seem to find any numbers for any oil pan gasket. The motor only had 20k and the gasket looks good so I think I may just reuse it.
Old 10-08-2007, 08:56 PM
babydeuce's Avatar
As long as it is not smashed or pinched, it should be fine. You could PM Matt @ Sdpd, he can look it up for you.....
Jack
Old 10-08-2007, 11:21 PM
Thanks!
Old 10-08-2007, 11:26 PM
Phoenix 5.7's Avatar
12580672 is the part number i found in my searches. i gotta get one also.
Old 10-09-2007, 02:01 AM
mikespeed95's Avatar
you can just use a camaro corvette one, the block is the same, therefore the flange on the pan is the same.
i always use a 'camaro gasket on my gto pan
Old 10-09-2007, 10:40 AM
i think everything is now L92 on SDPC
Quick Reply: Gto Ls1 Oil Pan Gasket Part Number?
