Valve covers with coils inside
I've seen these billet covers that are a cover within a cover that mounts the coils inside. Basically the second billet cover goes over the coils with a slot out the bottom for the wires. I Searched this site and others. I can't find them. Can anyone help?
I've seen all sorts of other billet covers but not like those described above.
Thanks
Jeff
Thanks
Jeff
Jegs has these:
"JEGS 50131 - JEGS LS1 Camaro/Firebird Ignition Coil Cover Kit
Do you want to keep the hood closed on your 1999-02 Camaro or Firebird just to hide the unsightly OE coil and valve cover combination? Our machinists have provided the solution with a CNC machined billet aluminum, ball mill finish, polished to perfection cover kit for an authentic show car appearance. Available with or without JEGS machined logo. All of the necessary mounting hardware."
i think some of those look a little too tall. i might be wrong if i see them on an actual engine,but from the pics they just look like they would stick up a little too much.
i think the gmpp covers painted with the coils relocated are the best looking stuff out there. katechs arent bad either
here's a link to a thread with different types of covers that you can decide on. https://ls1tech.com/forums/generation-iv-external-engine/727003-looking-really-trick-valve-covers.html
here's a link to a thread with different types of covers that you can decide on. https://ls1tech.com/forums/showthread.php?t=727003
Personally I like the look of the relocated coils with some aftermarket valve covers. To each their own though and there are some advantages to having such short spark plug wires.
Dumb idea....
But the coil manufacturer's will love you...
Wouldn't those covers keep the heat in and heatsoak the coils ....
There are dozens of Corvettes, Hot Rods, and F-Bodies running around with our covers and I have yet to hear of a single coil failure.
Carry on
And for the record check this out
Sweet valve covers also.
